Results 1 to 13 of 25
    FX-40 Lon Node Limit
    Quote Originally Posted by patsy View Post
    I'm not the actual user/programmer of the FX-40 in my company but I know that we use the FX-40 as a Regular Jace403. We noticed that every Fx-40 we've got from JCI in the last 3 months have a valid 3.2 licence. We never use the JCI appliance: we just commission (upgrade) the FX-40 like a normal Jace 403 in 3.2 . After that I can asure you that there is no difference between that FX-40 and a Tridium Jace403 except for the N2 port (and the 4 JCI module that are still in 3.0 version).
    We have use more than a 10 FX-40 that way (on jobs without the need for N2) and we can't see any difference from our Tridium Jace403.
    What is the Lon node limit count of 403 when above is done?
    And where is a good common place where I can by FX-40 off the shelf?
    Jun 2001
    SW Michigan
    I believe the 403 has a lon node limit of 27, unless you get the extended node version, which makes the lon node limit 120??
    126, the local device is default 127
    “It is impossible for one to learn what one thinks they already know"
    Quote Originally Posted by The Dog View Post
    I guess that is what I need to know, is FX-40 just a 403 or 403ext ?
    I guess I should open my eyes, the FX-40 documentation says it support up to 100 devices, I guess that makes it a 403ext.
    little rock ak
    i always leave my eyes open when doing controls
    Quote Originally Posted by rolo View Post
    What about when you type?
    Mount Airy, MD
    You upgraded with who m's software ???
    Jun 2006
    Quote Originally Posted by Chris_Worthingt View Post
    I just used the Fx-40 like any Jace403. When you upgrade a FX-40, the licences stays the same so the FX-40 is still from JCI and the licence reflects that.
    To upgrade any Jace to 3.2 you just need a pc with a Workbench in 3.2 and that the jace you are upgrading has a valid 3.2 licence in it.
    If you bought your Workbench via JCI, you probalbly don't have version 3.2 so you wont be able to upgrade.
    Mount Airy, MD
    Honeywell's 3.2 works ?? Without licensing issues then ???
    Mar 2006
    I would be careful trying that. Sure the JACE itself would probably upgrade fine, but the opening the Existing Station database could be a problem. I would try this with caution and with all backups and 3.0.106 close by.
    Once you go 3.2 you cant go back
    Mar 2006
    In that case I wouldnt gamble on it.
