Results 1 to 7 of 7
Thread: How big a hole in roof for gas pack?
    I am considering having two gas packs installed on my roof for a remodel. How big would the holes in the roof be for these two units? I am looking at American Standard 1.5 ton and 3.0 ton units. Some manufacturers make it seem that you need a hole about as big as the whole unit (for servicing?)(like 3' x 4'), but I don't understand why you would need a hole any bigger than the supply and return ducts (like 15" x 39"). I am concerned because this is an old house with only 2x4 rafters on roughly 2' centers, and I don't want a structural issue if I can avoid it. Thanks.
    Feb 2007
    Las Vegas,NV
    You dont need a hole the size of the unit. I am old fashion, and prefer to use an elbow out the back of the unit instead of mounting it downshot.
    If going straight down, do you still need the big hole?
    SC
    Nope. You can use two separate holes, one for supply, one for return. They can straddle a rafter if you like, and only need to be large enough for the duct plus the insulation.
    burlington county n.j.
    are the rafters big enough to hold it up ??????
    Feb 2007
    Las Vegas,NV
    2by4 rafters should be fine, I see many houses around here with two a/c units next to each other and some with 2 units and a couple of swamp coolers on top of that. Makes you wonder how they can hold all that weight, but they do. My house has a heavy tile roof with a composition pathway where my a/c sits and my trusses are only 2by4.
    Thanks. That's what I thought. The gas packs will be separated on the roof - one for each of 2 dwelling units (it's a small duplex) - so the weight will be spread out. This is an 82 year old house with a mostly flat roof. The "craftsmen" who built these old houses constructed what amount to site built roof trusses - 2 x 4 top and bottom chords with 1x6 tie backs on the outside walls with more bracing down the middle. The original deck is 1 x 6 tongue and groove and I put 1/2" CDX over that. I will add additional roof bracing around the units once they are in place. The roof is actually now better than more modern houses I have owned - partly due to actual size 2 x 4s and what appears to be all old growth fir lumber. I just want to minimize the size of the holes if I can.
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
