Results 1 to 6 of 6
    Exclamation Best humidifier, no hype.
    Looking for some qualified feedback , I have lots of experience with general 1042's, bulletproof humidifier, need larger unit. Looking @ general 1099 or is an aprilaire 600 or 700 any better, have always found aprilaire's a little flimsy and cheaply constucted.
    Thanks for your feedback.
    EWC Autoflo.
    Will add moisture weather or not the the furnace, is running for heat.
    wash dc metro area
    Ewc
    EWC Autoflo.
    Beenthere, Are you talking about the ewc steam humidifier? We sell three or four hundred of them a year but I have run into problems when they are installed on well water. Some of them scale up so bad that they will start tripping the fault codes after only a month. Do you ever run into this problem up in PA?
    Fin
    Only have one on a well that I remember, and it doesn't have that problem.
    South - Philly
    Humidifier
    I would agree that the EWC Steam unit is a great choice. I have used several and they have always performed very well.
    Inregards to the well water issue, I have bought the EWC water filter for several installations and they have worked great. They are not cheap but work well.
    Fort Worth, TX
    JOY!!
    Nothing to do with your OP...but I think Ren and Stimpy is hilarious!
