Results 1 to 13 of 17
    Jun 2006
    Fx40 push button
    I am trying to implement a push button from a Px screen that will reset a DCO on a Dx9100.
    I want a 1 to be sent on the down and then a 0 on the up to toggle the digital constant.
    Am I missing something simple?
    thanks in advance
    Kevin
    Dec 2006
    Quote Originally Posted by kevin stone View Post
    thanks in advance
    Kevin
    So you're looking for the one only for a second or so?
    Somewhere, WI
    Look in kitPx, you'll find "action button". I've used that for DCO's.
    Jun 2006
    Quote Originally Posted by HalreyAl View Post
    Yes just a second or two
    Dec 2006
    Set your DCO fallback to 0. You must do this because the following will only send the 1 value at priority 8. But when the priority 8 releases, the 0 in fallback will take control.
    Drag your DCO onto the px page, when the make wizard comes up, pick 'actions' on the left and 'Active' or 'Override ON' on the right, click ok.
    Double click the button on your px page to open Properties. Under the Action Binding header, click the space beside Action Arg. Unselect Prompt User, pick Custom from the drop down and type in the amount of time you want the 1 to be active. Ok, Ok, save. That should do it.
    Jun 2006
    Quote Originally Posted by ddcfreek View Post
    I must be having problems with th eargument
    K
    Mount Airy, MD
    Hmmm,,,,
    so your looking a 0 or a 1 ???
    Try a one shot to a numeric switch with true/false set to 0 0r 1 and other vise versa.
    Gravy
    Jun 2006
    I have been testing what you said on a bi on a unt and I am having no luck
    the value just stays at the fallback level
    thanks
    kevin
    Mount Airy, MD
    Try the above and put her in at 6 then,
    Mount Airy, MD
    Numeric switch here being the key part of course, it is what you want it to be....
    Dec 2006
    thanks
    kevin
    So you have the BI mapped as a Boolean Writable?
    Did you get through the rest of the setup OK?
    Jun 2006
    Yes to both
    Dec 2006
    Yes to both
    You got it to work then?
