Results 1 to 12 of 12
    Apr 2006
    Midwest
    Comfortview 3.1 connection problem
    My laptop does not have any built in serial ports, just USB. I'm trying to use a Quatech PCMCIA SSP-100 card but when I follow the IOM to set up the Serial PC card just keep getting error code 10 on the card. I know the card works, used it on many other programs. Checked some of the other posts about this issue and found mention of a Carrier bullitin but no specific info.
    Thanks in advance
    Aug 2005
    steward,
    Did you try re-installing the drivers for the card? OK
    Apr 2006
    Midwest
    I tried to "re-assign" port as the CCN Level II com port but when I do that I get the error that the card will not work and has been disabled.
    Feb 2007
    Dallas, Tx.
    It has always been my understanding that comfortview, for some reason, will not work through and add on serial port. I have had the same issue installing front end for users and had to revert to a PC with a true serial port on the main board. It was never explained to me why, my carrier rep. only said that "that's the way it is". I still program some stuff with service tool on a 1995 laptop. It ain't broke
    mike
    Jun 2001
    Louisville, KY
    steward...
    It was my intent to keep those bulletins when I left Carrier. Let me dig through some boxes. I couldn't find them on any of my hard drives, but they might be on a CD.
    I'll get back to you.
    See if this helps.
    Jun 2001
    Louisville, KY
    There should be one more that goes with that one.
    Thanks, djken.
    Melbourne,Aus
    Try this out..
    Aus..
    Upstate NY
    Carrier does not support and adapters for communications other than a direct rs232/rs485, until recently. Now they sell a Network Service Tool that is USB to 485. It works great and I understand it will support passthrough communications with ComfortView. Price is reasonable. Good Luck
    Apr 2006
    Midwest
    Thank you for the replies so far. Tried the methods in the attachments above, but still no luck. It will now label my com port as Level II and says its working but when I go to connect still says no connection when trying to upload. Just to make sure I'm not doing something wrong I loaded on co-workers computer with a "real" 9-pin and everything works great. Still looking for help if any other ideas for the SSP-100 card. Thanks again.
    Jun 2001
    Louisville, KY
    Where are you located in the "midwest"? Never mind. I found your union information. Looks like KC area.
    The controls department manager at Koch Air in St. Louis knows precisely how to configure that card. Maybe he'll give you a hand.
    Jul 2002
    NorthEast
    We have to keep one old laptop with a serial port on hand just for CCN
    However about five out ten times
    I was able to use a Belkin USB to serial converter
    which then connects to the Johnson Edgeport serial to RS-45 CONVERTER
    Sometimes the Belkin will also work directly with the Reccomended
    Carrier RS-45 converter
    But I know that Carrier does produce a USB to RS-45 converter
    Call your local Carrier controls division
    The only drawback is that they may want to install the
    drivers themselves
    Also make sure ComfortView is
    started in the Administrative tools/ services program
    Thank You
