Results 1 to 20 of 48
Thread: Carrier Condenser Explodes!!!
    Oct 2005
    Pacific Northwest
    Hmm Carrier Condenser Explodes!!!
    I had never seen anything like it before. Maybe somebody else has. The thing that gets me is the system was off, customer wasn't home and the neighbors said that it sounded like a bomb had exploded causing the fire department to be dispatched. R-22 system, ambient was about 80 deg. F
    Florida
    Only thing I can think of is someone put oxygen into the system.
    Oct 2005
    Pacific Northwest
    Well I have never done that myself, but I hear that if you did put oxygen into a system that contains oil you would probably be found in little pieces. Instant reaction if Im not mistaken.
    Oct 2007
    Dallas TX
    Maybe a corrosion issue. You can see rust where it (a pressure vessel in essence) blew apart in the last photo.
    Oct 2006
    houston
    i would have to guess oxygen too but I have never seen it first hand though i sure would like to ka-booom
    Aug 2005
    San Diego,CA
    Talking
    Cool!
    Sink or Swim!
    A Man has to know his limitations..
    To be old and wise, one must be young and dumb..
    Oct 2005
    Pacific Northwest
    Quote Originally Posted by maximusbravehea View Post
    yes there is rust present, but in all the cases I've been so lucky to have worked on, which have been subjected to rust or salt air corrosion (or as I call it, Coastal Rot) has one blown up. That sucker blew the jacket on the compressor to shreds.
    omaha
    if no one was home are you sure it was off
    Jan 2006
    indy
    check contactor. maybe it stuck closed
    Oct 2005
    Pacific Northwest
    Quote Originally Posted by johncavh View Post
    very good point. This is what the customer is claiming though. I have thought about this already and the thing that keeps puzzling me is, what if it was running, or what if the condenser fan motor failed with a stuck closed contractor without the customer knowing the compressor was still running and left. Whatever the scenario, I would like to think that the system would have some kind of safety feature to prevent it from violently exploding.
    Oct 2006
    houston
    the compressor has a high pressure relief that one blew up did they beat someone out of money?
    Nov 2001
    Port Saint Lucie, FL
    I see rust INSIDE the reciever, this problem was caused by improper installation...I.E. air (moisture that contains oxygen) and an arc from compressor motor windings without insulation(degraded by acid) conducted to ground. Was this a 410A system? How did it smell?
    My 2 cents here.
    It looks like heavy rusting at the bottom cap of the receiver caused the failure. I guess thats why they caution us about rusted freon or recovery tanks. Although, that receiver looks kind of skimpy on metal thickness.
    It appears to be a suction line receiver, so pressure would (should) be lower if the compressor was operating.
    Great post and pics !!!
  14. #14
    Oct 2007
    Florida
    Event
    Looks like the accumulator ruptured due to rust, and spun around. There would likely be liquid refrigerant present. The noise could be the sound of the accumulator whacking against the cabinet as it turned, like a playing card in bicycle spokes. Ask the earwitness if it was one short blast, or sustained. Never saw anything like it.
  15. #15
    Jan 2006
    indy
    it could have been a crank case heater that blew
  16. #16
    Toledo, Ohio, United States
    Slick Willis, Twilli wears this when working on carriers
    http://www.global-security-solutions.com/BombSuit.htm
  17. #17
    Jul 2000
    Northern Wisconsin
    That's one you want to see AFTER it happens for sure!
    Make sure if you find out any further info that you share it with the rest of us.
  18. #18
    Mar 2006
    Delaware
    Looks like the accumulator corroded through from the outside and let go, BIG TIME!
    Quote Originally Posted by napoleon-dynomite View Post
  19. #19
    Jun 2007
    Greenville,North Carolina
    Quote Originally Posted by twilli3967 View Post
    Twilli has one of them suits.Twilli use to defuse Bombs.
  20. #20
    Hell Hole Swamp
    I work in a coastal area also and have seen accumulators rusted way more than that one, Ive changed countless ones due to corrosion leaks, I have never seen anything remotely close to what happened there, more going on there than just rust
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
