Page 4 of 13 FirstFirst 1234567891011 ... LastLast
Results 40 to 52 of 158
  1. #40
    Mar 2009
    An image would be great. Could you send it to ?
    Last edited by Chris_Worthington; 10-27-2010 at 07:29 AM. Reason: Removed email address
  2. #41
    Apr 2009
    That would be great if you could send me a copy.
  3. #42
    Apr 2009
    Help setting up vpn to connect to insight from home with laptop have windows xp
    Can someone help with setting up vpn with my laptop to connect to insight from my home?
    Quote Originally Posted by xceldave View Post
    That would be great if you could send me a copy of cis. Thanks
    Last edited by Chris_Worthington; 10-27-2010 at 07:30 AM. Reason: Removed email address
  4. #43
    datamate copy
    does anyone have a copy of datamate???? or mind to send it...
  5. #44
    Jun 2006
    Des Moines
    Insight has nothing to do with your VPN connection from home to the facility. In addition, only your IT Dept can set you up with VPN access into your facility, so no one here will be able to help you in that regard.
    Dingman from Iowa~
    "A lie gets halfway around the world before the truth has a chance to get its pants on."
    - Sir Winston Churchill (1874-1965)
    The Dingman's webpage, featuring the Ding_Z
  6. #45
    Seattle, WA
    .. another request for Datamate or WinCIS .. I have neither. .. thanks!
  7. #46
    May 2009
    Oregon
    WinCIS is meant for Siemens techs but they have a balancer version of the tool that they can give out. I will have so many runs but it is the full version they use. You should have V29.1 or better.
  8. #47
    Apr 2009
    Cis Software
    Did you get a copy of Siemens Cis software if so could you send me a copy please. Thanks
  9. #48
    May 2009
    montreal
    I have a problem with CIS (dos version) because we change win2000 for xp.
    I need a new version, if someone have the new version can you send me a email plase.
  10. #49
    Oct 2007
    Daytona Beach, FL
    The CIS version for DOS will work fine under XP, as long as you laptop has a native serial port. Even then, it will still work, but it takes some tweaking.
    NewCIS Version 1.0
    http://rapidshare.com/files/145914054/Cis32.exe
    If anyone has a newer version than this, please send it to me. I will update my links with the new version. Email is
    Last edited by Chris_Worthington; 10-27-2010 at 07:31 AM. Reason: Removed email address
    NeonHomer
    BAS/BMS Technician/Computer Technician
    The definition of cruel joke is when you start work in BAS, and you run into your old T&B employer on the job.
  11. #50
    Jul 2009
    OK here goes, this is my first attempt on this site. I desperately need a copy of Siemens CIS, WinCIS. and, or Datamate. Whatever you-all find works the best with Siemens TECs. Any help is deeply appreciated!!
    Rick
  12. #51
    SF Bay Area
    Quote Originally Posted by RickFiodle View Post
    Rick
    "Hello, I'm Rick" probably would have been a better introduction. Plus:
    1)What you do for a living.
    2)State & City where you work?
    3)What your professional experience is.
    Please read THIS
  13. #52
    Jul 2009
    hvac/r-ddc tech
    Hi, I'm Rick'
    I haven't been able to get back to the registration page so I can finish filling in the professional data. Can you help?
Quality Home Comfort Awards
