Page 10 of 13 FirstFirst ... 345678910111213 LastLast
Results 118 to 130 of 158
  1. #118
    Jan 2013
    I would like a copy. I cant see peoples emails yet but if you can see mine =)
  2. #119
    Apr 2011
    You can download it from here:
    http://www.servitrol.com/axtools/
  3. #120
    Copy me too!?!
    Quote Originally Posted by dtharp1 View Post
    Can I get wincis too? As i understand it there is a newer end user gui based software out. Do you know what it is?
    Am I able to get a copy of a program that interrogates TEC field controllers, please? Would be a great help! Email in profile.
  4. #121
    Nov 2013
    San Francisco Bay Area
    Could you possibly send me a copy of that WCIS software from your post in 2007?
    Thank you
  5. #122
    HVACrepairmanca, I can get it to you if you put your email in your profile. It's about 50mb so will have to drop box it or usendit to you.
  6. #123
    Mar 2011
    Maine
    What type of issues are you having. Besides the obvious one. Over the years it has become a little harder to configure. Program or make changes in terminal. I know CIs, datamate ucis and wincis are all helpfull. Front end is always the best. My customers are pre 3.6. Most of the time. Know what the best would work for you is hardware.
  7. #124
    Nov 2013
    No specific problem. I want to check CFM output and supply air temperature without having to keep going to front end.
    - - - Updated - - -
    Updated profile with email address
  8. #125
    Mar 2011
    Maine
    It is possible to see the vavs with a smart device but sounds like the easiest for your situation. I have also utalized a flow balances hood which also provided real cal.
  9. #126
    Nov 2013
    I am not sure I understand how I can see the VAV's with a smart device. Are you talking about a smart phone with some special software? I know Johnson Controls has bluetooth devices,not aware of Siemens having the same. I had the Siemens service tech come out and he recommended getting the above software and related cable. If an easier way is available I am all ears. I would also like to change CFM setpoints on the ATEC as well.
  10. #127
    Nov 2013
    ddeman - are you able to send me that CIS software? Thanks
  11. #128
    Jan 2014
    In need of WCIS 3.0 or greater to setup some BACnet TEC's if anyone has it available I would like to get it.
    Please Help
  12. #129
    Jan 2014
    I am also in need of WCIS, were you able to get a copy.
  13. #130
    Jan 2014
    Actually I finally got it from a local McQuay dealer. Their Bacnet VAV
    Controller is made by Siemens. Wcis is 95mb zipped. All McQuays
    paperwork says use database or cis for setup. Check with them as they
    like to take away Siemens work...
Quality Home Comfort Awards
