    Aug 2008
    Siemens Slope/Intercept
    does anyone have any written information as to how slope and intercept is calculated in different siemens controllers?
    Aug 2013
    Halifax, Nova Scotia, Canada
    in insight, drag and drop the point in point editor. mid way down on the left is where you set the slope and intercept. click on the ... button, select the sensor/signal type and define the range - click calculate, click ok, and it will populate the values in the correct areas, save point.
    Aug 2013
    if using a terminal emulator (ie hyper terminal), point, edit, modify, enter the point name, adjust fields accordingly. Have to manually determine the slope and intercept though and manually enter the values.
Comfortech Show Promo Image
Comfortech365 Virtual Event
