Results 1 to 7 of 7
Thread: Aaon Makeup Air Unit
09-26-2007, 08:35 PM #1
Found a defective condenser fan cycling switch on one of these the other day. Does anyone know if there is a schrader core in the fitting? It is located in the discharge line.Thanks.
09-26-2007, 08:42 PM #2
Banned
- Dec 2001
- Southern Tier, NY
- 6,066
AAON .. makesa lotta work for me ...
ther's no good answer to your Q
09-26-2007, 08:59 PM #3
Slim you think the schrader could be hit or miss? I think I will just pull the charge and err on the side of caution.
09-26-2007, 09:22 PM #4
I'd back the flare nut out until I heard a faint hiss, and leave it until the hiss either stopped... or didn't. If it didn't within a reasonable amount of time like a few seconds, I would assume there's no valve core.
Some manufacturers are nice enough to provide you with a label stating whether or not valve cores are installed.Truth is still truth, even if no one believes it. A lie is still a lie, even if everyone believes it.
"It's called the american dream because you have to be asleep to believe it" -George Carlin
"A nation of sheep begets a government of wolves" -Edward R. Murrow
"I have problems just like you. One time, my dancing horse almost fell into my car elevator" -Mitt Romney
Buy american made goods & support locally owned businesses!
09-26-2007, 09:53 PM #5
All of their RTU's that I've done has always had schraders on the fan cycle and low pressure switches
But everytime I do one I'm prepared just in case
09-27-2007, 01:34 PM #6
Professional Member*
- Aug 2007
- Northern VA 38 degrees N by 76 degrees W
- 3,251
Beware FYI:
The unit probably has a schraeder core in it and most earlier equipment also had cores in the high side, but on newer equipment look for a tag on the high pressure side stating that it is a live port. New UL listings consider a core between the high pressure safety switch to be a valve and no longer allowed.
09-27-2007, 03:59 PM #7
Heads...there is a core
Tails...there is not a core
Assume there is not one just in case...play it safe. Being on the discharge line, it's too close to the weekend to show off your new tatoo from the gas.Some people just aren't smart enough to be stupid....
