Results 1 to 12 of 12
Thread: pressure temperture correlation
09-24-2007, 12:43 PM #1
New Guest
- Sep 2007
- 1
Can someone please explain the pressure temperature correlation of refrigerant
09-24-2007, 01:56 PM #2
The higher the temp/ the higher the pressure.
Walter Matthau
09-24-2007, 04:01 PM #3
and the lower the pressure the lower the temperature.
This might help : http://www.chm.davidson.edu/Chemistr...Theory/PT.html.................................................. ......................
---------Holland aint flat !!! it is hollow !----------- first thing my mommy told me was : learn to swim
09-24-2007, 11:20 PM #4
However
When you take Hydrogen at a high pressure, say 700# then drop it to say 5#, it will actually heat up.
09-25-2007, 09:06 AM #5
Any gas that will condense to liquid has a pressure/temp chart. In other words they are very predictable. I have a friend who delivers liquid Nitrogen. I have no ides what the pressure is at 75 degrees, but it is in the thousands of PSI. He hauls it in an insulate thank with a pop off valve that is set for very low pressure, I think it is under 10psi. As it pops off, it cools the liquid and maintains the low pressure and extremely low temp.
The most interesting thing about pressure/temp charts for different gases is they are each very unique. No two are exactly alike.
If you mix any two gases, one of two things will happen. Either they will occupy the space as two separate gases as the 400 series of refrigerants each condensing and evaporating at a different pressure/temp, or they will mix to form a new gas as in the 500 series of refrigerants, which evap and condense at the same pressure/temp.
However, even tho the gases may condense at a different rate, once both are condensed, the liquid will mix.
09-26-2007, 06:34 PM #6
Jax
You are absolutely
correct. Dont forget about the partial pressure. Every thing wants to come too equilibrium. It is ok.
09-26-2007, 06:49 PM #7
and when you take those laws and apply them , you can get refrigeration.
09-26-2007, 06:56 PM #8
09-26-2007, 07:00 PM #9
If you take hexane at 3500 psig and drop it to 100 psig it it will heat up also. Some things under pressure and released tend to act differently. Hexane at 3500 psig dropped to 2000 psig, there is a cooling effect.
09-26-2007, 07:07 PM #10
Hexane///////
You made that up.
Walter Matthau
09-27-2007, 01:10 AM #11
This is the answer to all that ails you concerning pressure, temperature and volume. You really should include volume with press/temp. The whole reason mechanical ACR works is because of a volume change.
http://en.wikipedia.org/wiki/Combined_gas_law
Here is another concerning aziatropes or blends:
http://en.wikipedia.org/wiki/Dalton's_law
And last but not least:
http://en.wikipedia.org/wiki/Henry%27s_lawLast edited by gruntly; 09-27-2007 at 01:22 AM.
Is this a Fabreze moment? C.Y.D. I'm voting white elephant. 2¢.
My competition are my best salespeople!
09-27-2007, 12:35 PM #12
- Aug 2007
- Oregon
- 19
Here is another place to look and read: http://www.refrigerants.com/frame.htm
A dirt bath is what you get when you quit learning.
