Results 1 to 10 of 10
    Drain line in Trane Air Handler leaking water
    We have a Trane Air Handler TWE036C140B0 model that just started leaking water from the drain line. The water begins to leak when the unit turns offs and drains about 1-2 cups of water. Any suggestions on what the problem could be? Thanks.
    burlington county n.j.
    drain line should be flowing water while unit is running.
    if it something new i would say check your filter. if unit is starving for air it may be pulling air up drain line and not letting water out.
    Thanks. Maybe it isn't called a drain line. There is a PVC pipe that hangs down from the Air Handler that has never leaked water before. Since original question was posted, I turned off the power to the unit and took the air filter out (which was just recently replaced) and put it back in and for whatever reason, it is no longer leaking. Will continue to keep an eye in it. Thanks again.
    DC Metro Area (MD)
    The drain line should be releasing water while the system is running and sometimes in bulk when the system turns off. This is just from what I've seen. Sounds normal to me, but maybe I'm not understanding you correctly. Yes, the PVC pipe would be the drain line.
    Midlothian,Texas
    restrictive filters
    I've seen this problem on units with allergy free, ultra pure, or anyother filter that costs over 4.00. All the ones that have ultra, anywhere in the name block too much air to work good in most units. If you have to use one of those filters , have extra return air filter grills installed. the old rule of thumb i was taught was 144 sq inches per ton of filter area. I don't have a figure for "ultra" filters but I would at least double it to 288 sq inches per ton.
    I don't put something like Farr 30/30 in the "ultra" catagory.
    other ideas?
    Jul 2002
    Slacking off right now
    maybe its his overflow pipe
    www.vetopropac.com - The best tool bags on the market - The offical tool bag of choice by techs everywhere
    Arguing with some people is like wrestling a pig - eventually you realise the pig actually enjoys it
    Gonads serve a useful purpose but are no substitute for brains
    Quote Originally Posted by The Penguin View Post
    could be, this diagnosing over the net is a pita..........
    don't pay worth a d@mn either.....
    Jan 2002
    Ft.Worth,Tx
    That air handler has (2) pipe exits on coil area, one is main drain and other is secondary, maybe draining into pan under coil or air handler. If this is the case and you have water in secondary pan your main line maybe clogged up. If you can see a metal pan with water in it, then your main is stopped up. Suggest you turn off system and call for service before you have bigger issues with water.
    'Life begins with the journey each day'
    Jun 2007
    Round Rock
    Probably needs a little maintenance done by blowing the drain out. If not the pan could be cracked or it needs a Ptrap.
    Jul 2002
    Quote Originally Posted by t527ed View Post
    yep ain't that the truth I though awhile about posting - I think I'll keep things on the down low for a while
