Results 1 to 13 of 35
    Delaware
    Rinnai water heater
    Hi to all,
    HVAC contractor here. I want to install a gas hot water heater. My kids.....well I guess I should say all of us must use to much hot water. My electric bill is always so high. I want to change out my water heating method. I'm not asking how to install one, I can do that but rather I want to see if anyone has installed a Rinnai water heater in their home and is happy with it? If not an on-demand type, what did you install and are you happy with your selection?
    BC, Canada
    I don't have one in my home, but we've installed many of them and the majority of our customers like them. They have a minimum flow rate though, so you can't just trickle the hot water. We tell our customers to turn it on full. That's about the only problem we've every had. Much better system to heat hot water than water tanks.
    We have had our Rinnai for almost a year and a half. We never had a problem with it, my wife would never let me change it back to a tank
    "We'll have to outwit the fiend with our superior intelligence." Yukon Cornelius
    Some people are like Slinkies---not good for anything, but still bring a smile to your face when you push them down the stairs!
    Delaware
    2 for 2 so far better start picking out the one I want.
    I see the offer them in both LP and Nat. The town I live in is going to Nat in about 1.5 years, Hope I can convert to natural gas at that point.
    We had some installed in a school system here. We had to take them out & install tank type. They gave too many problems.Too many parts to go bad. With tank type there are very few parts to go bad & it they do, they are easy to get parts for & repair. Depending on you water conditions you need to flush these systems about every 6 mo.We have to install flush kits & purchased a pump kit to perform the flush on units
    I may be wrong ,but I don't think you can convert these units from 1 fuel to the other
    If you choose to go this route good luck to you. I install the tankless cause that's what the customer wants,but I wouldn't have 1
    BC, Canada
    Yes, Farmboy is right. The water conditions can make a big difference. We installed a Rinnai in one area where the customer did not have water treatment, and we've had a few problems with it. Regular maintenance (flushing) is required.
    Jun 2007
    Minneapolis, MN
    Tankless water heater.
    Noritz, Rheem, Rinnai and Takagi all make respectable tankless water heaters. Ask three agreeable contractors for a bid and references. If they try to talk you out of it, get another bid.
    Water condition is important, so if you have hard water get a bid for a softener to go with your new tankless and keep thinking GREEN.
    MA
    Delaware
    I'll put the water heater in myself. I have town water, so I think I have the water conditioning thing covered. The only thing holding me back it to see if I can convert it to natural gas when our new town line is run. We have city sewer, just got city water and now the gas. But it may take 1-2 years to complete. So it will have to be propane to start.
    burlington county n.j.
    make sure it can be converted before you buy one, if it can make sure you get everything you need right from the start.
    years ago in my previous house i did the same thing with a power vented water heater.
    found out when the natural gas came down the street that my 2 yr old tank could not be converted............
    St Paul, minnesota
    Quote Originally Posted by energy star View Post
    Hi to all,
    i thought about putting in a tankless water heater, instead i installed a 50 gallon power vent water heater with R-20 insulation. my reasons were my 2 kids like taking long showers & with a tankless you get endless hot water & an endless gas bill. The other reason most of the tankless heaters you have to be certified to install them. so you can take a class. the problem is that there is so many exclusions that there isn't really a warranty at all. now if you have a hot tub tankless is the way to go. with the 50 gallon I also installed a timer which shuts it off @ night, so I'm not reheating it @ night. it has a 6 year warranty. parts are easy to get anywhere. even when it shuts off @ night the water is still hot in the morning. just my input.
    Jan 2006
    Hangin out with you losers
    This unit is easy to convert and I have never had any callbacks
    We dont sell norwitz but I hear good things about them also
    http://www.rinnai.us/Products/water_...Technical.aspx
    I remember my first day,It was fun!
    South Texas
    As per the information I get from asking this questions of those who deal with them a lot, I would have to advise you on seeing the cost effectiveness from a tank to tankless.
    A tankless costing 4 times that of a tank system. The average life of a tank water heater- 10-12 years. The average life of a tankless- 10-12 years. The amount of energy saved and the maintenance costs.
    The savings in energy usage is usually taken by the initial investment. But then an investment isn't an investment unless it makes you money.
    The size of the tankless must be correct for the gallons per minute vs the temperature of the incoming water in relation to the length of time. It is possible to run out of hot water or run with water not as hot as you would like, thus a larger capacity heater will cost more.
    If cost or savings is not a big issue- your good for either one.
    Delaware
    Please don't flame me......
    Sometimes I have this idea to incorporate a a 50 gallon gas or oil hot water heater with my gas furnace. I would install a coil in my duct and a small circulator pump on the the water heater and run the pump so I would always have hot air coming up out of my duct work. Kinda a pre first stage heat. Then my mind takes it always jumps too a solar panel on the roof. Always looking to save money, but I yet have acted on either of these ideas.
