Results 14 to 17 of 17
    Feb 2002
    Houston Tx
    Does the Cond unit have a drier installed ? Low on freon pump it up and you'll be fine..
    Tampa Bay
    Quote Originally Posted by mldncx1 View Post
    I'm a semi-retired HVAC service tech with some install experience.
    Any ideas?
    It appears to me that you are getting a little more experience now...
    Next time...NO SHORTCUTS !!!
    Some people just aren't smart enough to be stupid....
    FL
    forget about pumping it down and taking it apart, charge by superheat first, i would try this before going through all that unless you really want to put in the dryer.
    East central Indiana
    Yesterday I pumped down the system, blew backwards thru the lineset and ecoil, and inspected the metering pin. I didn't find anything so I pulled a vacuum down to 300 microns and made sure it held for five minutes. Then I released the R22. I doubt I'll be running the AC anymore this year, but if I start it up next year and it makes the same noise, I'll have to figure I already had air in the system.
    Thanks again for all the responses!
