Results 1 to 9 of 9
Thread: I Need Help
    Biloxi MS
    I Need Help
    I don't know if it is my washer or dryer, but my clothes are coming out of the dryer with grease stains on them. I pulled a white T-shirt out and it had yellow staing all over it. Would someone please tell me what I need to look for.
    Jul 2001
    VA
    ___________________________________________
    Victoria,Tx
    Probably a yellow crayon from one of your kids. Buy a new dryer, they are cheap. If not break out the wd-40 on the grease. Then dish detergent to use as soap. It loosens the surface tension of the grease, wax, parrifin or what ever you call it. But some new shirts also. That one had "ring around the collar" and was dingy. Guys clothes are cheap too. Just the basics.
    Jul 2002
    Slacking off right now
    Ummm did the clothes go in with stains? How do you know thats a grease stain? might want to change stain remover brand if so.
    suggestion:
    Inspect the dryer with a flash light for stains/ marks
    Inspect the washer for stains/residue.
    Put your washer through a cycle with some detergent and bleach - no clothes
    Graffetti remover is the only product I found that took Ball point pen ink of a plastic dryer drum.
    Afterwards put some clothes through - reduce the amount of detergent you use - use about 1/3 to 1/2 what he manufs say to use (unless you have hard water- then use 2/3 to 3/4) use a warm/warm cycle this time
    www.vetopropac.com - The best tool bags on the market - The offical tool bag of choice by techs everywhere
    Arguing with some people is like wrestling a pig - eventually you realise the pig actually enjoys it
    Gonads serve a useful purpose but are no substitute for brains
    Cincinnati
    Just cut the stains out of the items. Problem fixed.
    I think I answered this somewhere else??
    Hey cockroach, don't bug me!
    Lucedale, Ms
    Hmm
    May be grease out of the gear box coming up thru the base of the tub around the shaft. May have a bad seal. Just a guess!
    Colorado flatland native
    Maybe you were drunk when you ate them Nachos last night.....
    Walter Matthau
    Oct 2007
    hehe
