    vulcan hartt fryer
    How would you check a milivolt gas valve for ground
    One terminal to ground. If it is a Robert Shaw unitrol with the pilot magnet; then approx. 10 ohms. The main valve is less than 1 ohm accross it. Hope that helps.
    Quote Originally Posted by FloridaAR View Post
    thank you i called robertshaw and that is correct
