I'd check on who's going to maintain and service the boiler in the future. Personally I've seen hundreds if not thousands of boilers installed that easily lasted through the 1-year warranty period. Then 2 or 3 years into use, they needed a service repair and couldn't find a tech with the knowledge to service the unit. Used to do work for a manufacturer and I can't tell you how many times I was referred calls from them and when I got to the home and the door opened, I identified myself (like they couldn't read the truck ads?) and the first response from the client was "Thank goodness I finally found someone who knows how to work on this boiler". There's a lot of people willing to take your money for the install and they might in fact do a great install. But who's going to be there when you do need service? That's the most overlooked question in the industry, IMO. As a side bar, in our state there's a world of difference between the installations done by a plumber and those done by a heating company. Two different animals. Most plumbers in our state put "...& Heating" on their trucks just to get the installs and they NEVER have to live with what they've installed. In fact, around here if it's a new gas pipe, the gas company will pick up the 1-year of warranty. The installingn plumber is done as soon as he cashes your check. As you can probably tell, that's a sore point with the techs at our company. We know what we need to do (all the isolation valve suggestions for example) to make the job a good one at the start and forever, for the life of the equipment. But we constantlly battle with the low ball bidder who's installing the same equipment to a lower standard and will never be the one to maintain or service it. LIke the military pilots say, "Check your Six".
