Results 14 to 19 of 19
Thread: Trane XL14i Two Speed Fan
09-08-2007, 08:14 PM #14
I couldn't tell the sound diff between high & low anyway. The swept wing blade is quieter, cheaper, nothing to go wrong.
I don't blame Trane's relationship with big orange for cheapening of any product. The entire industry is responding to John Q. Public's demand for the cheapest price they can get. Only way to do it is cheapen the product.
What's the best made furnace? A ThermoPride. What's the most expensive furnace? A ThermoPride. What's the least sold furnace? ThermoPride. Can't have the best for the least and the public wants the least $$.
09-08-2007, 11:08 PM #15
09-09-2007, 06:10 PM #16
- Oct 2006
- Vallejo, CA
- 154
Answer??
The XL14i did have a 2 speed outdoor fan motor that would work with a 1 stage furnace. The process of changing speeds is similar to your vehicle radiator cooling fan. Ever hear the fan in your motor change on a hot day? Same thing, just not as noticeable with the XL14i. With this ever-changing industry, one must accept change and be o.k. with not being the first one to know. Keep it simple.
11-09-2007, 03:20 PM #17
- Nov 2007
- 13
XL14i substandard heat output - xl15i much higher ?
If the XL14i is great, why is the heat output so low in airdirectory database versus xl15i of same series, almost 5K btu difference in output.
XL15i Weathertron 4TWX5036A1 4TXAC037AS3 *DX1B080A9H3 36,000 12.00 14.25 Capacity (Btuh) 37,200 47 deg 8.70
Capacity (Btuh) 24,000 17 deg
XL14i Weathertron 4TWX4036B1 4TXFH041AS3 *DD1B060A9H3 36,000 11.70 14.00 32,400 8.30 20,
LUXAIRE, UNITARY PRODUCTS GROUP Acclimate 8T HL8B036F1 FC/MC62D+MV12D+TXV 36,000 13.35 18.00 36,000 10.00 25,800
One of the members pointed this out to me, really freaked me out because I can't figure out what would explain the huge difference between the 2 units of same series, or are these measurements flawed because they all use different furnace/coil combos.
Are these measurements considered to be accurate and valid?
I am about to install a xl14i hp in northeast climate and heat efficiency is crucial as backup system is oil.
Don't know what the price diff between 14 and 15 is but I feel like changing my order at least to xl15i or worse canceling (find new contractor) - I still have a couple of days to do that. SHOULD I OPT FOR XL15i for way better heat output - will that save a hundred or 2 a year (4kbuth diff)
Comments? help?
Homeowner
11-09-2007, 03:41 PM #18
- Jun 2007
- Metro St. Louis
- 181
I pretty much ignored the high temp heat outputs (47*). The low temp heat output is what I focus on. That will drive how cold you can run your HP before aux heat.
That said, same indoor coil, same furnace, the difference is 4K BTU at low heat (about 20% more heat).
I didn't shop the Trane's much, so I don't know what the other differences area between the 14 and 15.
11-09-2007, 05:24 PM #19
Professional Member*
- Aug 2007
- Northern VA 38 degrees N by 76 degrees W
- 3,251
look for the B in the middle of the model #4twx4036 "B" 1000a the website is dated.
