Page 3 of 3 FirstFirst 123
Results 27 to 29 of 29
  1. #27
    Do a load calc.
    Then pull out that over sized 4 ton, and install the correct sized unit.
  2. #28
    Myrtle Beach, SC
    You would do well to install a 2 stage unit there.
    But your unit is over-sized or it would not short cycle.
    If you installed a dehumidistat to bring the strip heat on (reheat) then the compressor would run longer and bring the humidity down. High humidity is not good for electronic stuff like computers.
    A dehumidistat would be a cheap fix up front, but expensive to operate.
    Doing what beenthere said would be the best long range solution.
    Remember, Air Conditioning begins with AIR.
  3. #29
    thanks for your replies, I did end up suggesting to go with electric heat strips. For now I shut off the continues fan.
    again thanks Im always trying to learn. Only been if the field for 2 1/2 year.
