Results 1 to 13 of 13
    honeywell focuspro 5000 inside temp not accurate
    Just got a new Honeywell FocusPro 5000 thermostat. The current inside temp on the thermostat is now 78 but my professional register thermometer is reading 81.5 sitting right next to it. Is the temp reading on the stat an average reading or is it supposed to be accurate at any given point in time? The cool setting is set at 78. The system does cycle on and off, on at 81.5 and off at 78.1 but the inside temp on the stat never changes..just stays at 78. I am beginning to think that the inside temp on the stat is just a lower limit and not the actual temp. Any thoughts?
    Jun 2001
    Louisville, KY
    Search "rounding feature".
    Rochester, MN
    There is an offset option, and have it set up 3˚
    Quote Originally Posted by mayguy View Post
    Is this a factory setting? Can I change it? If so, how?
    Spoke with Honeywell and they say only the 8000 series has the offset feature.
    Kentucky, Michigan, Ohio, Arizona, Colorado, Nevada, and Califormia
    One more, basic thought..... when the stat was installed, was the hole where the stat wire exits the wall insulated ?
    "Surprised ?! If I woke up tomorrow with my head sewn to the carpet, I wouldn't be more surprised."
    Clark Griswold
    Quote Originally Posted by lra View Post
    Not installed yet, just running off the battery.
    Well then, plz disregard my previous post !
    Clark Griswold
    Rochester, MN
    Quote Originally Posted by Physoft View Post
    Ok, Yeah, I just looked at the papers, they are right, only the VisionPro does that. Sorry..
    Put your temp sensor in a glass of ice water and see if it comes to 32˚.
    Jul 2002
    Zelienople, Pa
    Let me guess....EBAY?
    Close as I could get was 35.5 and that was right on the ice cube.
    Quote Originally Posted by Gunnery Sergeant Hartman View Post
    Yep! And your not the only one that wants to puke.
    Rochester, MN
    Then the t-stat is fine.
    In iced water, it will be 32˚.
    Sounds like you need a new professional register thermometer.
