Results 1 to 8 of 8
    Alberta, Canada
    Resistance heater Frequency
    Best place to post this due to the high volume of info geeks like myself
    I have an odd question to do with using a European appliance here in North America. Its a cookie maker that as far as I can tell is just a resistance heater. (like a waffle iron) No fancy electronics etc.
    obviously 220v 50hz 1000w. I am 99% sure that 50hz to 60hz on a pure resistance load will not make any difference. My wife has her heart set on this, so I just need to know that its not going to be an issue.
    To answer some of the obvious questions that will come up straight away:
    -YES I know that 120v wont cut it. DUH. I will be wiring a new 220 plug.
    -No I dont want to do any internal work to the iron.
    "I'm really easy to get along with once you people learn to see it my way."
    "I'll try being nicer if you'll try being smarter."
    Feb 2005
    I'd do it. And it will probably run on 110 as well, though the current will double. Still - it's only 1000W so you'd be pulling about 10 amps - not a big deal at all considering your kitchen outlets should have their own dedicated circuits.
    But there may be some auto-shut-off/safety/timing circuitry etc. internally that steps the 220 down to an internal control voltage. If so, this won't like 110 as the resulting control voltage will be halved..
    the 50/60 Hz thing won't be an issue except your cookies may cook 20% faster than advertised
    Nikko
    Bryan,
    I just have to ask....is this for making beaver tails?
    Alberta, Canada
    Mmmm Beaver.
    Thanks nikko I figure its going to work just fine as well.
    No not that type.....there's a place in Ottawa that make these things call beaver tails...flat pastry, brown sugar.......Doh, never mind
    Alberta, Canada
    haha. Actually I just punched the numbers and 120v will not work. At 220v with 1080w the elements total 45 ohm. with that as a constant the output of the heaters at 120v will only be 321w at 2.6A. that wont cut it.
    Are you Sim from Chinook by chance simsd?
    No,
    Originally from Ottawa. Now L.A.
