+ Reply to Thread
Results 1 to 9 of 9
Thread: a/c icing up coil on open display cooler...
    Apr 2006
    anybody find this to be a problem is that a/c diffusser is right above open display cooler, this is a federal open type with no defrost except when cut-out pressure is met,a/c blowing around 65 deg. air at system, should this display case be moved or diffusser disconnected or blocked off, any recommendations on getting around this... thanks..
    Never Assume Anything
    Apr 2001
    Quote Originally Posted by freeeze43 View Post
    What refrigerant is in this unit and what are the Low pressure control settings (cut-out & cut-in).
    Jabs
    maine
    the diffuser should be moved, it will blow 55 degree air into the case moving the 30 degree air out.. The case might work fine but will have to work harder for sure..
    at local wawas in this area (nj) i see the returns right above cases & i always wondered what effect if any it had on either system
    On a bull named Foo Manchu
    Never had one ice up because of the duct work but have seen them not getting down to temp. They moved the vent and problem solved.
    Apr 2006
    Quote Originally Posted by Jabarco View Post
    Jabs
    r22 with cut out at 64psig and cut in at 35 psig
    Your settings are too low for not having a defrost clock. I cant tell you exactly what you want without knowing what temp your trying to hit. 55/70 is close
    Apr 2001
    The settings you have are a good setting for a walk-in cooler but on an open case with R22 I would use 66 psig as cut-in & 40 psig as cut-out.
    Jabs
    Vancouver , Canada
    Talking Open case concerns
    The air from a diffuser WILL disrupt the invisible air curtain and cause spillage of the cold, dry air from the case - so you make that air up with warmer, more humid air from the HVAC system in the store - two things will happen - iced up case and in the very least, inability to hold temperature/ longer run time.
    Does the case have a seperate air curtain? If so, ensure that portion of it is working properly.
    Years ago, Hussmann used to publish the cases had to be out of any air stream ( that includes ceiling fans ) and the design parameters dictated 75 F DB and 50% RH maximum - food for thought.
    Superheat and subcooling tell it all !
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
