Results 1 to 9 of 9
08-26-2007, 09:39 PM #1
- Nov 2006
- 20
Trane XV90 exhaust running while TS is set to off
Just noticed today when walking by outside that I could hear and feel air coming out of the exhaust from the furnace, I could also feel that the intake was sucking in air.
I checked my TS again and it is set to System-Off. When I stand by the furnace it sounds like a low hum like it is trying to start up.
Just wondering why the furnace would be doing this when TS is set to off. I turned the power off to the furnace for now and will be calling a tech this week. I always like to post here first and get some feedback so that I can understand the problem and also ask the tech the right questions when they are here at my house.
Seems strange to me that the furnace would be trying to run when the TS is set to OFF.
08-26-2007, 09:40 PM #2
- Sep 2002
- Boise Idaho
- 1,032
is the fan set to on on the t-stat? it runs at 50% fan speed which is real quiet. Also they run for several minutes after satisfying a cooling call.
matt
08-26-2007, 09:52 PM #3
Professional Member*
- Oct 2006
- So. NH
- 652
08-26-2007, 09:54 PM #4
- Sep 2002
- Boise Idaho
- 1,032
Im not sure he knows what he's saying, are we talking about the draft enducer motor for heat or the indoor blower motor that moves the air in the house?
matt
08-26-2007, 09:59 PM #5
- Nov 2006
- 20
The TS has fan set to off. Sorry I didn't know what the terms were for the different fans. The indoor blower motor is not running, it's the draft fan which I can feel and hear when I'm outside where they exit the house.
08-26-2007, 10:18 PM #6
most likely a open limit switch
You can't fix stupid
08-26-2007, 10:49 PM #7"We'll have to outwit the fiend with our superior intelligence." Yukon Cornelius
Some people are like Slinkies---not good for anything, but still bring a smile to your face when you push them down the stairs!
08-26-2007, 11:08 PM #8
yes good point.
it's possible it is though they are quiet
08-27-2007, 01:36 AM #9
- Nov 2006
- 20
Yes I do have AC and it is working fine. It was on 2 days ago but the TS has been set to OFF ever since.
I thought I would try something else so I turned the the TS on to heat to see what would happen. After a few minutes with nothing happening the Furnace beeped three red LED codes which from the back of the furnace panel means pressure switch fault. (I did also check this LED before I asked for heat when I first saw the problem and it was doing a steady beep which means everythings OK I think.)
It's nice to have some more information at least but still doesn't explain why the draft fan was running continously.......strange.
