Results 1 to 7 of 7
Thread: new install
    richmond va
    new install
    one thing i never done is install gas logs. do you need to come in from the bottom or through the side of the fireplace.thanks
    Boss it was working fine when I left!!!
    Peter
    Jul 2001
    VA
    What does the manufacturers installation sheet say?
    May 2005
    Madison, WI
    bottom? Is the original fireplace a pre-fab? Usually there is a gas knock-out to come in with. For masonry often times the easiest way to come in is though the ash trap.
    S.E. Pa
    Cool
    You need to know what logset/ burner you are installing. The location of the gas inlet will dictate what is possible. Since most valves are located on the right hand side (because most people are right handed), a gas line entering the right will tend to push the logset past center. You don't want some jumbled up mess of spaghettic bunched up at the valve. Usually, by entering a factory built fireplace knockout from the left or a masonry from the ash pit as JTP described is the best approach. You can easily route you line while keeping it centered, towards the rear with adequate secondary airflow in the sides.
    Do you know if this fireplace and room are suitable for gas logs?
    Are these vented or ventfree logs?
    If ventfree, are they allowed to be installed here and do they meet the sizing guides and have adequate ventilation?
    Has anyone performed a Level II inspection on this fireplace and chimney?
    Lot's to know and consider before charging off into this work. I suggest you get some training and hearth credentials first. Start off by talking with your local hearth dealers.
    HTH,
    Hearthman
    richmond va
    the fireplace was built with the house back in 1947. I had it cleaned 2 years ago and have ran a handfull of fires since it was cleeaned.. i was planning to use ventfree. the fireplace is 2 feet wide.
    Peter
    Virginia
    If you are installing a ventfree, you need to be aware of the mantle overhang and the need for a hood. There should be a section in the owners manual that addreses this subject.
    May 2005
    Madison, WI
    You should consult a PRO for a ventfree. There are so many little things that need to be considered. Is the cost saved on labor by DIY worth you and your families lives? Also, make sure you get a good CO detector.
