Results 14 to 26 of 30
    Florida
    Quote Originally Posted by firecontrol View Post
    I dump the charge from my hoses after every check. Matter of fact I disconnect from the high side of the equipment first, open the high side of the guage to the crossover and then slowly open the low side of the guage to the crossover. IE: I put what liquid I took out of the system right back in. The only thing thing left in my guage set when im done is whatever gas it'll hold at the pressure of the low side. Anyone ever measured how much that is? Oh........ I run 5' hoses if someone is going to do the measurement.
    I pre-charge my gauge hose set before I hook them up.......
    yeah,yeah, that's the ticket.
    Actually I don't.
    Nov 2000
    Upstate, SC
    Only 1 oz or so, huh? I remember reading somewhere that a 6 ft hose held 5 ounces of liquid and the article warned against using the high side gauge unless you had reason to. Have I been mislead all these years on something else???
    I always attach the high side gauge I don't know subcooling otherwise. I will recheck my gauges with the liquid line filled but that was what I got the other day.
    Fort Worth, TX
    Quote Originally Posted by smokin68 View Post
    I've done that for a critical charge ice machine using 404A. Learned by doing that they were DEAD serious about that machine being critical charge!
    Wouldn't cross my mind to do it for a resi R22 or 410A system, however. I do isolate the high side and then let the remaining liquid charge in the hose back into the low side. That's just good practice.
    Phoenix,AZ
    Quote Originally Posted by shophound View Post
    Along with the AIR too?
    Air is always purged through the gauges upon hookup.
    Houston,Tx.
    Quote Originally Posted by GAHomeOwner View Post
    When a technician is testing the charge level or subcooling or superheat, and is using gauges with hoses that are several feet long, how much Freon is lost from filling up the hoses? Should the technician have a canister of Freon with him to replace what is lost when he completes his system check? Thanks.
    O God! how to folks get so bored? I wished I had time to worry about stuff like that,
    heck with my busy life that would be like meditation to me.
    Phoenix,AZ
    Quote Originally Posted by BigJon3475 View Post
    Just checking.
    Fort Worth, TX
    Quote Originally Posted by kbghdg View Post
    Of course not. Air is purged via diminimus release when gauging up. I always purge a little every time even with low loss fittings or ball valves.
    Would you pump down your high side hose into the low side if you thought air was in your hoses?
    I didn't think so.
    Would you even hook up to a system with just plain ol' regular hoses and not purge them before adding refrigerant or even for merely checking pressures?
    I didn't think so.
    I don't let air remain in my hoses either, no matter what operation I'm performing with my manifold set.
    Fort Worth, TX
    A similar thought crossed my mind...
    ...interesting what questions get asked in this section at times.
    Houston,Tx.
    Hey good to see a Texan on the Educational Committee and folks think were are just good
    old "dumb" country boys in Texas, I guess the "intelligent" owners here think differentially.
    Everything is bigger in Texas
    I use 4' hoses with a ball valve on the end, then another 10" hose screwed onto the ball valve. Each of my 3 hoses is a 3 piece assembly(long hose-ball valve-short hose). The short hoses with a ball valve permanently attached are not a good idea because you can't purge the air out of just the small hose if you keep pressure in your manifold like I do.
    I can't stand low loss fittings!
    When I disconnect from a system, I open both valves on my manifold briefly to clear any oil, and close the ball valve on the liquid side.
    I let the system pull all the liquid out of my hoses and manifold, then close the ball valve on the vapor side and disconnect my hoses. I only loose the little bit of refrigerant in the 10" hoses.
    This leaves my manifold and hoses under some pressure from the remaining vapor.
    The next time I hook up to a system, I connect my hoses, purge the air out of the 10" hoses and open the ball valves.
    I'm loosing less than an ounce of refrigerant from connecting and disconnecting to a system.
    Before I got a 2nd set of digital gauges, I used the same set for R-22 and R-410A.
    Before hooking up to a system with a different refrigerant than the last one I worked on, I would bleed my gauges and manifold down to 0psi, and hook up to the system, then purge my hoses and manifold with the new refrigerant. Still probably loosing less than an ounce of refrigerant.
    Now that I have 2 digital manifolds, I just use one for each refrigerant.
    RSES Certificate Member
    RSES-SWRA President
