Results 1 to 13 of 30
    Atlanta
    Loss of Freon When Checking Subcooling Superheat ??
    When a technician is testing the charge level or subcooling or superheat, and is using gauges with hoses that are several feet long, how much Freon is lost from filling up the hoses? Should the technician have a canister of Freon with him to replace what is lost when he completes his system check? Thanks.
    Kentucky & Michigan
    If the hoses have low loss fittings like most of ours do, the loss is minimal and would take several thousand "checks" before affecting performance.
    "Surprised ?! If I woke up tomorrow with my head sewn to the carpet, I wouldn't be more surprised."
    Clark Griswold
    Jul 2001
    VA
    Fair question
    With low loss fittings and proper techniques you won't lose enough to make a difference with regular service. Should they put more in just because they hooked up? No. The amount you are talking about is not readily measurable, so all they would do is screw the charge up.
    ___________________________________________
    Lancaster PA
    Should he have a jug of gas in the truck yes.
    Should he try to put .25 oz. back in, no. ( presuming low lose fittings )
    Nov 2005
    Be careful, many of the techs on this site and many in the field use one set of gauges for all residential refrigerant types. Which means they dump the charges on their gauges after each use. If your system is near critical and the tech has 6 foot hoses it could affect system performance.
    I STARTED WITH NOTHING, AND I STILL HAVE MOST OF IT!
    Quote Originally Posted by emoney1971 View Post
    (cough)
    Bull****
    Please explain to this group what you mean by "critical charge" on a residential unit and how loosing less than on ounce of refrigerant will matter.
    Jul 2001
    VA
    critical charge .....resi AC....... naahhhhhh
    besides..... most resi guys do not dump the hose charge between calls, they deal primarily with just a few refrigerants and have a set for each.
    Jul 2000
    Northern Wisconsin
    I dump the charge from my hoses after every check. Matter of fact I disconnect from the high side of the equipment first, open the high side of the guage to the crossover and then slowly open the low side of the guage to the crossover. IE: I put what liquid I took out of the system right back in. The only thing thing left in my guage set when im done is whatever gas it'll hold at the pressure of the low side. Anyone ever measured how much that is? Oh........ I run 5' hoses if someone is going to do the measurement.
    Sep 2006
    Southern California
    diminimus
    Jul 2001
    VA
    Yeah firecontrol.... I think every good tech does that.... I was just saying that you would not vent the hoses to atmosphere between calls.
    Florida
    Quote Originally Posted by firecontrol View Post
    I pre-charge my gauge hose set before I hook them up.......
    yeah,yeah, that's the ticket.
    Actually I don't.
    Houston,Tx.
    Quote Originally Posted by GAHomeOwner View Post
    O God! how to folks get so bored? I wished I had time to worry about stuff like that,
    heck with my busy life that would be like meditation to me.
    “I am glad that I paid so little attention to good advice; had I abided by it I might have been saved from some of my most valuable mistakes.” - Edna St. Vincent Millay
    The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth.
    No Guns…No Freedom…Know Guns…Know Freedom.
    Fort Worth, TX
    A similar thought crossed my mind...
    ...interesting what questions get asked in this section at times.
