Results 1 to 13 of 24
    Nov 2005
    Venezuela
    Hoshizaki KM-500 MAE short freeze cycle
    Hi everyone. It's been a couple of months since I've logged in. I hope you're all well and making plenty of money.
    I have a Hoshizaki KM-500-MAE icemaker in the shop that's going into the harvest cycle right after the 5-minute lock out. Normally that would be a water problem or a float switch problem, but not this time.
    I've got plenty of water, the float switch is brand new (and works), the pump and capacitor are brand new (and work) and the thermistor resistance matches the resistance chart in the manual.
    Everything else on the machine is doing what is should, so I have to suspect the control board.
    Does anyone have a better idea before I tell the customer the bad news?
    Greeting from Venezuela, especially to Ice-meister.
    Toronto
    You could check the air holes at the top and the bottom intake to the float switch. It could well be the board though I've never had this particular problem with the board. I try to carry a new board for all the major ice machines so I can quickly eliminate the board as the problem. The other thing is whether the switch on the board is on Alpine or C. If the main power 10 lead cord has a white at the end it is a C board. If there is no white it is an Alpine. Maybe that Orinoco water is just ornery.
    I'm sure you've checked all that basics. Did you sequence the improved E board by the test switch 2,3,4,1 ? Smells like a freeze timer problem on that board.
    FEN
    Jul 2000
    Guayaquil, EC
    Pull the float switch connector and put a jumper across the board terminals. If the machine goes into harvest immediately after the lockout, it ain't the float switch......it's the board.
    Nov 2005
    Venezuela
    Mojo and DoctorIce
    Thanks, guys.
    It's an Alpine board on a oldish machine. Ran through the board diagnosis in the manual, and everything checks out fine.
    Parts for icemakers are expensive and hard to get here, so I don't carry a spare board, though it makes a lot of sense. I'll have to send to the U.S. for a new board if that turns out to be the problem.
    Whatever machine I'm working on, I always pray it's not the control board failure. I can repair most of the electromechanical parts, or replace them with something similar, but the boards are a big problem.
    I've rebuilt machines, replacing the electronics with electromechanical parts, or using stuff like the Danfoss controllers, but Hoshizaki logic is a bit tougher to simulate.
    I'll check out those air holes, Doc. And the Orinoco water, too. Maybe there's a Piranha fish stuck in the float switch.
    Best wishes from Venezuela.
    Nov 2005
    Venezuela
    Hi Icemeister...
    "Pull the float switch connector and put a jumper across the board terminals."
    Did that first. It's not the float switch, I'm pretty sure of that. Anyway it's brand new. Thanks for the suggestion, though.
    On another subject, the icemaker project we talked about a couple of months ago is still alive. Found someone to make the evaporators for me. Learned how to calculate the heat load and size the compressor (thanks to your tips and links). Designed the control system. Now to design the casing, get the bits put together, and build the prototype. I'd like to have one made by Christmas. I'll keep you posted.
    Charlotte, NC
    Quote Originally Posted by mister frío View Post
    Just a thought, but, if you have plenty of water and the float is good, check the check valve for the drain. They are the triangle shaped plastic part the pump has a tube going to. You have one inlet tube for the pump and two outlets. One outlet sends water through the top section for evaporator and the other sends it down the drain when the pump is reversed. When the check valve is partially held open the water will be forced down the drain causing the float to break and call for fill. When that unit calls for the second fill it goes into harvest. Just a thought.........
    alexandria va
    hoshis dont have a second fill. if u jump the float and it still goes in at 5 min order u a board. also check txv bulb clamps. they are problably rusted with would explain your high suction. peace out jbb
    Nov 2005
    Venezuela
    Thanks, JTRefrig...
    I'll check out those clamps. Good advice.
    Greetings from Venezuela.
    Toronto
    I have a fair number of used Alpine boards. I prefer them to the new board when the machine starts having harvest problems. Could I send you a used board (checked out of course) without causing a lot of customs problems?
    I'll send it for free but should I put a value on it?
    Nov 2005
    Venezuela
    Thanks, DoctorIce....
    ...that's a really generous offer. If you were a bit closer I would gladly accept, but there are a few snags with sending anything:
    1. We don't have a regular mail service worth the name. My sister in the UK regularly sends me stuff, and only about 50% of it gets here, and the other 50% takes up to six months and a great deal of sleuthing to get hold of. So if it's anything important she has to use FedEx or similar.
    2. The cost of your shipping a board to Venezuela via FedEx would probably be pretty high, and I'd hate to put you to that expense.
    When I order parts from the U.S. I have to specify courier delivery and pay extra. That hurts, because we have strict currency control here, and I have to buy US dollars on the black market at double the real value.
    However, it's great to know that there's a helpful guy like you up there in Canada. If you're ever down in my neck of the woods, count on somewhere to stay. As they say down here, "Mi casa es tu casa".
    Nov 2005
    Venezuela
    Hoshizaki update...
    This machine is going to drive me crazy! Today I got so fed up with it I pulled out the control card and all the wiring. I checked every single component on the machine, right down to the on/off switch. On a workbench I wired up the transformer to the board, and ran the diagnosis cycles again with plenty of room to watch what happened. I put the tester across the 4 relays and watched them open and close, as well as checking the pin continuity on K1.
    The only out-of-the-ordinary thing was that the (downloaded from Hoshizaki) manual indicates that there are FIVE relay/pin checks, activated by bridging the float switch terminals FIVE times. But on this board, the relays cycle after FOUR bridges, omitting the second bridge shown in the manual. Perhaps it's an updated manual and I have an out-of-date board.
    Anyway... Close to 6 p.m. satisfied that everything else worked just fine, I rewired the machine (somewhat tidier than before), fired it up and was surprised that it ran a full cycle perfectly normally! I only ran one cycle because it was getting late.
    Now I have another problem, if the machine works just fine tomorrow. I didn't actually "fix" anything, it just started working. I'll have to keep it running in the shop for at least another week before I can return it to the customer with any degree of confidence.
    Maybe it was just a loose connection, but I'd sure like to know which one!
    I'll keep you posted on tomorrow's results.
    Thanks guys. Greetings from Venezuela.
    Charlotte, NC
    Quote Originally Posted by jtrefrig View Post
    Yes it does, it has to fill during the harvest cycle to have sufficient water for the next cycle........huh?
