Results 1 to 12 of 12
    Oct 2002
    Florida Panhandle
    Cigarette Smoke Eliminator
    Hi all.
    Wonder if any of you can give me some advice on products that are good for removing cigarette smoke. Its for one room about 12X20, I have looked at many products via the internet, but trust the opinions here a bit more.
    There is no central air, just a Mini Split.
    Roy
    A man is no less a slave because he is allowed to choose a new master once in a term of years.
    Lysander Spooner
    May 2005
    Lubbock Texas
    We do quite a few casinos. Most of our products are geared for commercial use.
    Nov 2001
    Port Saint Lucie, FL
    Activated carbon.
    Nicorette has a variety of products for eliminating cigarette smoke.
    Here and there
    Talking
    I use a Sanuvox p-800gx in my office. It helps but not 100%. The smoke control I have done in larger areas with uvv/uvc, outside air and ventilation are a little to complex for a 12x20 room..... unless they got the $$$$.
    Apr 2002
    NASA can recycle piss but I would rather drink fresh water.
    Ventilate
    http://www.ductstrap.com/
    WI
    Quote Originally Posted by Carnak View Post
    Ventilate
    Bwahahahahaha, I truly could not have said it better myself.
    Apr 2002
    Roy
    They used to sell the ceiling mounted smoke eaters which were electronic air cleaners. In a bar you would have to clean them steady else they started to arc like a bug zapper.
    Madison, WI/Cape Coral, FL
    Exhaust the smoke to the outside. You can not replace the oxygen or remove the CO/other gasous pollutants. TB
    Jun 2001
    Louisville, KY
    Ventilate
    We recycled farts on the submarine. H2 burners. CO2 scrubbers. Talk about stale air.
    "Prepare to ventilate."
    Oct 2002
    Florida Panhandle
    You just dont know when to quit, do you. You may want to rethink your avatar, considering your views.
    Roy
    Lysander Spooner
