Results 1 to 8 of 8
    Jan 2014
    Buderus GB142. 6L error any takers?
    Ionization code. Fuel/air mix. Replaced sensor( basically flame sensor) No Gucci! Didn't have manometer but 500 gal tank 65% full. Or empty as I was looking at it at the time. It was coldest day of yr in long time! Just coincidence idk? Think could've been low Lp pressure
    Mar 2013
    Billington Heights, NY
    Gucci's are sold at Saks 5th Avenue. You can try there.
    This forum requires that you wait 20 seconds between posts. Please try again in 50 seconds.
    Experience - knowing when to get the hell out of the way and plug your ears. "Don't be a sissy. Turn it on!"
    Poodle Head Mikey - "the world is well populated with the unknowing and the uncaring and the stupid."
    Jan 2014
    Wow you guys r brutal. I like it. But still no buderus guys huh? Just comedians.
    Jan 2014
    Sounds like you know more bout saks than anything. Heh heh.
    Mar 2013
    i've worked on buderus but:
    - you havent provided any details in coherent english language
    - you havent proven whether you are a tech or homeowner (we cannot provide diy advice)
    also, reposting the same topic over and over again will only annoy the techs here and pester the mods, which may result in your profile being banned.
    so, based on the available information given in ALL of your threads i can only say "call a professional"
    Jan 2014
    I stated I was a tech. S-2 from CT. I tried to reintroduce my question in a more understandable fashion maybe you didn't take time to reread it. I thought I would get some serious answers here and have seen replies to lesser inquiries. Sorry I'm not up to your standard. Maybe I should step up to the pedastal your standing on. Thanks but no thanks. I guess this site isn't for me.
    Jan 2014
    My apologies. I stated I was a tech in a different thread
    - - - Updated - - -
    Although everything else stands.
    Mar 2013
    by posting in AOP residential it is assumed you are a non-tech and no professional advice is given other than to 'call a professional'
    no technical advice is given in any of the open forums. if you want technical advice, apply as a professional member and repost your question, with data details, in an appropriate closed forum.
Tags for this Thread
