    Oct 2012
    HVAC Terminology
    I could use some help with some of the terminology used in HVAC. I read some of these posts, and everybody has their own way of saying something.
    For example, making a connection with silver solder
    One definition of silver solder, is using a brazing alloy with 45% or higher silver. Melting range is around 1200* to 1400*.
    Another definition of silver solder, is using a soft solder such as stay-brite, which has a silver content, but melts at 400-500*.
    Which is the correct term?
    Mar 2013
    swan valley idaho
    I'd say its a general term for regular old 15 percent silver solder. Oops i mean brazing rod.....
    Haha I think most people just say silver solder but are referring to " brazing" then again i have been known to say i had to " de-thaw the coil" and other hillbilly stuff all the time.
    Oct 2013
    MA
    Personally, I always classified solder as soft material. IE: stay-brite, using propane or mapp to heat.
    But that's just me.
    Sent from my XT907 using Tapatalk
    Nov 2013
    Mass
    Mechanical code states;
    Solder has a melting point below 800degrees.
    Braze has a melting point between 800 degrees, and the plastic melting point of the material being joined.
    Welding is done at the melting point of the material.
    If I'm using silver Braze, I say silver Braze. Braze is Braze, solder is solder, and silver bearing solder is silver solder.
    Chase
    Mar 2013
    Springville, NY
    Quote Originally Posted by Tom42 View Post
    But that's just me.
    you mean you dont use propane for brazing 15%?
    Nest is poo...
Comfortech Show Promo Image
Comfortech365 Virtual Event
