Page 1 of 5 12345 LastLast
Results 1 to 13 of 65
    Oct 2011
    Birmingham, AL
    Heat pump compressor keeps failing
    Hi, I had two Weather King 2.5 ton heat pumps with electric heat strips installed a little over 2 years ago. About 3 months ago the upstairs heat pump breaker flipped and the compressor wouldn't turn on.
    I had someone replace the compressor and everything seemed fine until about a month ago when the upstairs breaker flipped again and the compressor wouldn't start.
    Today I had a different tech have a look and he said the compressor is bad again. He recommended I have an electrician look at the wiring to make sure there aren't any problems before he installs a new compressor or he's afraid it will fail again shortly.
    The downstairs unit has been fine for over two years.
    Do you guys have any ideas?
    Thanks.
    Southold, NY
    Why are they failing? This has to be answered first.
    WAG something’s wrong with the installation. Find another contractor.
    Oct 2011
    Birmingham, AL
    I hear you. I just paid $ just for the tech to tell me to get an electrician. Now should I pay another HVAC tech just to tell me the same thing maybe? I find the last guy more reliable since he turned down a $+ compressor replacement job from his quote. He also recommended I call Rheem but they won't do anything of course since the contractors are responsible.
    For what it's worth the power company has been doing work on our block the last few months. They've installed a huge pole with what looks like quite a few large transformers. The first contractor said a surge over so many minutes could ruin the compressor. The second contractor said the power issue was a possibility but need an electrician to verify.
    Oct 2011
    Birmingham, AL
    The last contractor also said the supply wiring looked like it may be a little undersized. It looks like the standard 3 wire white jacketed home wiring. I think they reused it when going from the two 2 ton air conditioners (gas heat) to the two 2.5 ton heat pumps.
    Mar 2013
    Billington Heights, NY
    what does the breaker size say, what does the wiring jacket print say, what does the condenser rating plate say for breaker size/amps?
    Experience - knowing when to get the hell out of the way and plug your ears. "Don't be a sissy. Turn it on!"
    Poodle Head Mikey - "the world is well populated with the unknowing and the uncaring and the stupid."
    Oct 2011
    Birmingham, AL
    Quote Originally Posted by HVAC_Marc View Post
    The breakers are 20A on each leg so 40A total for each pump. I'll have to check the wire gauge and condenser rating and get back to you.
    Mar 2013
    you may have 2 separate breakers but the total is still only 20.
    Quote Originally Posted by sqwerl View Post
    Take a picture of the outdoor unit nameplate and the wiring at the disconnect going to the unit showing the wire type. Also the circuit breakers in the panel
    Northeast Ohio
    The failure(s) could be related to poor installation practices. Improper charging, improper evacuation, poor oil return, contaminated refrigerant, mismatched equipment the list goes on. You need to determine what is killing the compressors in "this" system.
    DEM
    Okay. So you had 2-2 ton A/Cs. Then someone installed 2-2.5 ton heat pumps. Did they ever check to see if the duct work was big enough for the 2.5 ton heat pumps.
    May 2008
    Missouri
    Oh....wait....YOU DON'T ADD THE BREAKER SIZE TOGETHER TO DETERMINE HOW MUCH POWER IS FED TO THE UNIT. Two 20A breakers does not equal 40amps. Sounds to me like you've got the main feed wire undersized to each heat pump and yes this could cause premature compressor failure. Especially if the failure unit is much further from the breaker box!
    Oct 2011
    Birmingham, AL
    See if you can see these attachments. The 4x20A breakers are for the heat pumps. The two wires running outside best I can read say 12/2 W/G 600V UL. That's the only useful numbers I can find. Sounds to me like common household 12 gauge wiring and TOO SMALL.
    Aug 2010
    West Monroe, LA
    Quote Originally Posted by heaterman View Post
    Agreed! You need to find a Company that can give you a answer to the question. What's killing the compressor? Without that you wil be spending $$$ to replace just to have it go fail again!
