Results 53 to 65 of 123
08-05-2007, 07:36 PM #53
Ok Bama..... I gotcha.
08-05-2007, 07:47 PM #54
Email your address and I'll send you copies of my x-rays and mri's.
If you are going to tell people that you have to touch all three legs together to get "hit" then you sir have no idea what you are talking about and you may get someong killed.
By the way, if you tie all three legs together, the resulting plasma explosion will likely kill you outright.
Next time you come across a delta transformer system, measure l1 to l2 and see what you get.A delta system is a good short-distance distribution system. It is used for neighborhood and small commercial loads close to the supplying substation. Only one voltage is available between any two wires in a delta system. The delta system can be illlustrated by a simple triangle. A wire from each point of the triangle would represent a three-phase, three-wire delta system. The voltage would be the same between any two wires
08-05-2007, 07:49 PM #55
Banned
- Dec 2001
- Southern Tier, NY
- 6,066
08-05-2007, 07:54 PM #56
08-05-2007, 08:03 PM #57
Perhaps this will help.
08-05-2007, 08:10 PM #58
08-05-2007, 08:15 PM #59
08-05-2007, 08:18 PM #60
I'm glad you found these diagrams. Take a close look at them & EXPLAIN to this dumb a$$ redneck how you can have 460v run through you and only be in contact with 1 or even 2 legs. If you're unfortunate enough to have all 3 legs hit you, then I agree. That's hard to do. Most of the time it's either between 2 legs or 1 leg & ground. Either one is not going to send 460 through you, it takes all 3. Keep digging through the internet to try & prove me wrong & maybe you'll learn something in the process.
08-05-2007, 08:22 PM #61
Come on out to the site tomorrow and I'll show you 460 volts between L1 and L2, your meter or mine.
Then what's on L3?
08-05-2007, 08:24 PM #62
08-05-2007, 08:27 PM #63
- Feb 2005
- small island in the Pacific Ocean
- 558
Wow! Time for a group hug. 120, 240, ... it all hurts like hell and can kill based on circumstance.
Why do all threads get derailed into pissing matches.
08-05-2007, 08:30 PM #64
Did you read the diagram? How about the part where it says a to b= 480, or where it says b to c= 480 or maybe where it says a to c= 480.
If you grab onto the l1 and l2 and the potential between them is 480, then you're going to send that voltage thru your cheast. Same thing if the transformer is 575, 460, 240, 24 or 5 volts.
Whatever the voltage between the two is, thats what it is, wether you want to believe it or not.
You're same guy who used up four pages trying to tell me 2 phase, 4 wire power does'nt exist are'nt you?
08-05-2007, 08:30 PM #65
