Results 1 to 13 of 19
Thread: JB gauges
    FL
    JB gauges
    Anyone use the JB digital gauges? I am wondering if they are any better or worse than YJ and Digicool, they all have the same functions just that JB is 200 buck cheaper the other thing that i question is the temp probes, they have a stero-like connector instead of the K type. And what do you do to the probes to get a good reading? I use pipe clamps and a fieldpiece that serves me well.
    Quote Originally Posted by jvillehvac View Post
    They were tested on another site. I had them for a day and they broke. You cannot compare them to the Digicools. The only things about them that were any good what so ever was the temperature function seemed to be good and the manifold was decent. Its your choice but they are at the lowest end of the digitals. The Yellow Jacket and DigiCools are the same made by DigiCool. The Y/J and DigiCools have a ****ty strap probe however Digicool is coming out with a clamp type probe and they have a water tight connector at the unit. The Y/J and Digicool only have one probe so that is a minus. If price is what is going to make the decision for you then be warned, you do get what you pay for.
    portland, oregon
    dig gauges
    I have not had any problems with my JB digital gauges, They are less expensive than other makes but work well, The temp. probes are excellent,
    they are a half moon type probe with a couple velcro straps.
    I like being able to toggle through my readings as I charge a unit and
    being able to see the sh and sc readings digitally displayed is helpful.
    one thing I dont like about them is they only give you three ports on the manifold with the smaller vac hose, otherwise not too bad for the buck.
    wethead72....
    Jul 2000
    NW IL.
    My boss got a set of those JB's when they first came out he's on his third warranty set. A plant maintenance crew in town is having them same problem with them.
    I have the Testo 523. The version that first came out over two years ago. Only problem I had is that the plug recently broke off the temperature probe. The newer 523 uses a different configuration plug for the temperature probe.
    So
    you have to ask is that $200 less going to be worth the possible hassle.
    The display on the JB set is horrid. It can only display one value at a time, and won't display the saturated temp.
    The YJ 40802 (the one on the right) uses a 41067 probe which has changed from the thicker wire (because it can pick-up heat of a solar load) to the much thinner wire and a 3/16 diameter NTC. Lose the velcro strap because it can slip. For 6 bucks mount the probe to a Irwin quick release clamp.H.D. or Lowes.
    FEN
    FL
    thats for the feedback. think i will keep saving, i really dont need them but they are on my list to buy by the end of the year.
    Nov 2005
    We have 3 sets of the J/Bs out in the field. Been out over three months now, all
    with no problems. Hosed up and hung in the back of the service van.
    If you want a little more bang, I would go with the Testos.
    The single display on the J/Bs is a little bit of a downer, but the dual temperature
    readings serve a lot of value.
    Also, the J/Bs do show saturation temp., but only on the low side.
    Testo also has the ability to go wireless on temp. probes. Y/J and D/C do not.
    For us, we like the J/Bs. When we want to invest more in digitals, we will go with
    the Testos.........No doubt.
    GF
    Attachment 3288Attachment 3284
    I think some of you will remember this that was used on the Tiff digitals
    Attachment 3285
    This is the inside of it.
    Attachment 3286
    This is the inside of the J/B digital
    Attachment 3287
    It is not a good picture but you can see that the sensors are about the same and are unshielded millivolt sensors. The low side on the J/B quit working for awhile and then the high side was way out compared to two other DigiCool digitals.
    Attachment 3289
    Attachment 3290
    These are shielded transducers in a DigiCool 1200 and are in all of the DigiCool digitals and the Yellow Jacket digital. They are stainless steel and do not get bothered by any electrical noise. The Testo digital uses a ceramic transducer that is sealed with a oring. I don't know if the leak problem that they have had is because of this or something else.
    It looks to me like the JB is not even in the same league, in both construction and display quality, as the Digi-Cool/YJ and Testo products. Not surprising, since it is substantially less expensive.
    The circuit board on the JB looks like something that came in a Heathcraft kit....
    I do have one question for the guys with the JB sets.
    If the gauge has pressure on it, and you turn the power off and back on, does it still read that pressure, or does it auto zero when you turn it on?
    Master Cool is also coming out with, or has come out with, a digital refrigerant gauge set. If the price range I saw a rumor about is true, <$200, it must be the biggest POS going...
    Nov 2005
    I am not sure about that particular instance Mark. They are supposed to be powered
    up with no pressure. If left on a system, they should continue to read the same
    pressure however. I will see what I can find out.
    Yeh, not too sure about the Master Cools........around $250.00 for manifold only.
    They are supposed to be out in the automotive industry now, with 134a profile.
    From what I understand, they will leave them there for a while before they introduce
    them to the HVAC market.
    REFCO is bringing a set out also, later in the summer I guess.
    I will hold my judgement on all of them until I get a chance to see and use them.
    Lower price does not necessarily mean a POS. Remember Toyota?
    I will not have anything to do with the Y/Js or the D/Cs. Single sensor? what
    is up with that. For right now, regardless of others luck, we like the J/Bs. We have
    not experienced any problems with them. If we do, they have a 1 year over the
    counter warranty. Dual sensors allow splits on the condenser, offering Temp.1
    Temp. 2, plus deltaT of T1 and T2. Read SH and SC at the same time. Come
    off the condenser walk inside and read deltaT at the evaporator, all with one
    instrument.
    Like I said before, when we want more in a digital gauge, we will go with the
    Testo. They are for true system analysis, trending etc.
    GF
    Hey Mark have you thought about hooking the DigiCool and the Testo together with t fittings to see how they track one another? I did that with the j/b and DigiCools. It was hooked to a 134a auto fitting but works on a 1/4 flare.
    You are right about the Mastercool digital. I saw the one they make for Mac Tools and it's right there with Fisher-Price.
