Results 1 to 10 of 10
Thread: Legit or not...
    Feb 2013
    Cary NC
    Legit or not...
    [ATTACH=CONFIG]445021 I dont like it or consider it safe regardless of how skirting code is.
    Nov 2010
    Cincinnati, OH
    Even if its b-vent with another layer I would be afraid it would cool it too much causing condensation and rot out the chimney. Better then some stuff I see but I'm going to go with illegitamate.
    Feb 2013
    Cary NC
    Makes for an interesting Delta. I saw it and informed the tenant of the possible complications and safety concerns I had, so now in the landlords best interest or lack there of.
    New Mexico
    Looks like some tinner didn't know how to make a pair of pants.
    Tracers work both ways.
    S.E. Pa
    You mean aside from the lack of vent rise, draft hood connector or support, no you can NOT penetrate an air duct with gas piping or venting. Any more pics?
    Dec 2013
    N.W. Indiana
    I thought I seen some things or 2 but that's a new one is that the gas flue going through the plenum?
    Apr 2013
    Pennsylvania
    Definitely not
    Cleveland, OH
    I've seen them go through returns before (in new construction even). Not kosher. Shouldn't pass an inspection anywhere.
    Good? Bad? I'm the guy with the gun.
    Feb 2013
    Cary NC
    I had to open return grill to see for myself. There was 6 in flex that terminated at the furnace. I wondered why that wasted space was not employed
    Jul 2010
    nebraska
    I've seen it before. The duct has a metal sleeve for the vent to pass through so it's a lazy mans pair of pants. The vent is not in contact with the air stream. Same concept as the box around the flue running through the return air in a down flow furnace.
Comfortech Show Promo Image
Comfortech365 Virtual Event
