Results 1 to 2 of 2
    Chapel hill nc.
    stand alone dehumidifier
    any recommendations? for a sealed crawl space. something that will perform well and last.
    B
    thank you
    Madison, WI/Cape Coral, FL
    Dehu TB's work is never done. Before installing the dehu, cover the earth with plastic, close the outside fresh air inlets, and seal the outside air leaks. If open combustion devices are present, provide the code specified fresh air inlet necessary to provide make-up air for removal of the by product of combustion. High efficiency, more durable than most, and operates in a cool space best describes the one most expensive dehumidifier sold. Check out Santa Fe, Ultra-Aire. There are others that are ok. Dehu TB
