Results 1 to 7 of 7
    eastern north carolina
    Question rtaa/rtac replacement fan motors
    has anyone found a replacement for these motors outside of ma trane
    Ontario
    RTAC fan motor
    I think it is a GE motor
    WOODS-Air Movement
    Central Texas
    Please do not do that!
    You are not going to find one that will make you happy. I know ours is not cheap but there was a lot of engineering that went into it.
    dde
    Sep 2006
    Ohio
    I have seen other motors that work and I have even called to get pricing on some. I can't remember the make of the motors, but I ended up getting one from Trane because they were about $50 less and they even had some on the shelf. Don't forget to get a new fan blade.
    N.E. IA
    You could try some of the other Trane suppliers. I've used Midwest and Tarrant as well as the local supplier. Don't forget to factor in freight charges.
    "Wheel" mechanics work on "Wheel" chillers
    Central Texas
    Thumbs up Trane parts
    Try our parts center. Ask for Brian or Walter.
    512-416-8822
    Austin, Texas
