    Corrosion Grenade - does it work?
    Anyone have long term experience using a product like Corrosion Grenade? Obviously its just a zinc anode, which is the same thing boaters have been using for decades to protect metals on their vessel.
    Well, does it help a condensing unit against corrosion?
    Apr 2004
    I've heard installing a shaft zinc on the suction line at the compressor will actually increase coil life on coastal units. Shaft zinc's are cheap too. Like 10 bucks at the marina. Just make sure you get one that will fit snugly.
    Florida (some where) way-south
    Dudes it really does works
    great idea, it had to be made by a egg head.
    they also use zinc on outboard engines to protect the engine
    doing one call at a time.
