Results 1 to 2 of 2
    Dec 2013
    No heat from furnace after replacing thermostat batteries
    Our thermostat was displaying low batteries, but after replacing the old batteries with fresh batteries heat no longer operating properly.
    The thermostat appeared normal immediately after battery change however once the heat kicked on the furnace would only stay lit for about 1 minute. After that the thermostat would display "hold -ac".
    I took another thermostat in our house and tried it at this location and the same thing occurred. I have restarted the furnace and it still wont stay lit for 1 minute.
    Any advice would be appreciated!
    Mar 2013
    Billington Heights, NY
    we cannot supply DIY advice. you need to call a professional.
    Experience - knowing when to get the hell out of the way and plug your ears. "Don't be a sissy. Turn it on!"
    Glennac - Failed my biology test today: They asked, "What is commonly found in cells?" Apparently "BL*** people" wasn't the correct answer.
    Poodle Head Mikey - "the world is well populated with the unknowing and the uncaring and the stupid."
