Results 1 to 13 of 32
Thread: increse CFM ??
    Chicago
    increse CFM ??
    If I had a 3 ton ac with an ahu that derlivered 1200cfm- would installing a fan that produces 1400-1600cfm improve the amount of cooling being delivered???
    Dec 2003
    Nevada
    What symptoms do you have that you are trying to correct? The scenerio you suggest could just make it worse.
    Quote
    “Engineers like to solve problems. If there are no problems handily available, they will create their own." Scott Adams
    "We can't solve problems by using the same kind of thinking we used when we created them."
    Albert Einstein
    SW FL
    Exclamation
    Quote Originally Posted by jmiles View Post
    ... Would installing a fan that produces 1400-1600cfm improve the amount of cooling being delivered ?
    NO !
    Designer Dan
    Florida
    It would remove less humidity.
    In short, NO.
    400 CFM/ton is about perfect here in Florida.
    Boise Idaho
    no!!! more cfm = air temp would be warmer, less air, air would be colder. The out-put is determined by the comp btu, moving more air will not change that, it will change moisture removal or run the risk of freezing the coil (if you slowed it down)
    matt
    Apr 2001
    Yes, more CFM would increase the suction pressure and in turn increase the capacity of the condensing unit. However, that increase in capacity will be an increase in sensible heat and less latent heat which will probably result in less comfort; depending on your geographical area.
    Jabs
    Might, or it might not.
    Depends on the duct system, you might not get more then another 1000 CFM.
    You will lose humidity control if it does move more air.
    Apr 2006
    400 cfm per ton of cooling, more airflow across the coil will cause the coil to freeze up, you must try to keep a load up on the coil for an efficient system..
    Jan 2006
    Near Atlanta, GA.
    Huh?
    You'd better think about that one.....
    burlington county n.j.
    Quote Originally Posted by freeeze43 View Post
    hows it do that??
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by smokin68 View Post
    delete, i need my reading glasses!
    Dec 2006
    Middle Tennessee
    can't agree with this either!
    Nov 2000
    Eastern PA
    Less humidity control. Increased air pressure problems. Increased load problems. All around bad idea.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
