Results 1 to 10 of 10
    Is there a problem with my NEW A/C?
    Why does the A/C unit turn off before the target temperature is reached? I have my thermostat set at 74. The temp on the thermostat said it was 77 but the unit turned off.
    Why does it do that?
    SA
    go thru your set up menu on your t-stat
    what t-stat do you have
    carefull no DIYS
    FL
    what type of tstat do you have. I have seen the honeywell pro 5000 do this one time, changed it out and all was good. have your contractor come out to look at it, verify proper operation.
    We have a honeywell thermostat. Not sure of the model though.
    Dec 2006
    New Jersey
    did you program your tstat. do you understand what hold does?
    Jul 2005
    Quote Originally Posted by RyanJ View Post
    If this happens every cycle, then the t-stat is out of calibration. Could be the set point, or it could be the thermometer reading, or both. Just set it to a temperature that keeps you comfortable.
    Southern NJ
    Wink
    Is it digital or round. If it's a mercury bulb type stat it must be level on the wall. If it's not it can cause what you are describing. If digital it could be out of calibration like earlier stated.
    I love to Cook...HVAC is a hobby that pays the bills!
    Quote Originally Posted by acmech13 View Post
    Yes, to both of your question.
    Quote Originally Posted by makinmoney View Post
    It's digital.
    Dec 2006
    New Jersey
    has system reached temp yet?
