Thread: 404a Pressures
    Jun 2007
    new jersey
    404a Pressures
    The tag on my ice maker says high side pressure 500 and low-side pressure 250 is this correct ona commercial ice machine. Not familiar with 404A but that sounds high to me.
    Mar 2006
    That has to be MAX pressures before something bursts.
    500 PSIG on 404A = over 150F
    250 PSIG on 404A = 110 F
    Jan 2006
    Near Atlanta, GA.
    Those are test pressures, all that means is that the circuits are rated to handle that much pressure. Normal operating pressure of 404 is nowhere close to that.
    Jun 2007
    those are the max pressures rated for the evaporator and condensing coil, I pay attention to those when im using nitrogen for leak checks after i have installed a compressor or other.
    Jan 2006
    DFW Metroplex
    Quote Originally Posted by couplux View Post
    Yup - a little high indeed. Water doesn't freeze well at +104F.
    Means you most likely will have a hand grenade sitting on top of a bin if the system pressures should ever go beyond those limits.
