    Feb 2005
    A test between swamp coolers and AC IAQ
    This is a test from two home in SLC, one with a cooler and one with central air.
    Two days later, that's what we found. The home with the air conditioning measured 6.9 micrograms of particulates; the home with swamp cooler measured 19.1, about the same level as the outside air, at 20.1.
    here is the link;
    http://www.ksl.com/?nid=148&sid=1502605
    Apr 2002
    that's a no brainer
    http://www.ductstrap.com/
    Feb 2005
    True, but you do hear all the time about how indoor air is dirtier than outdoor air?
    Quote Originally Posted by cool-blew View Post
    It is, just in ways that don't show up on a particle counter.
    Apr 2002
    Off gassing, carbon dioxide more fine particles.
    In a cold area, you take the filters out of the outside air units in the winter. They frost up, but there are no bugs, pollen, snow keeps the dust down.
    Swamp cooler is changing the air inside a home pretty frequently in cooling. The cooler pads double as the filter and they are not the greatest, so it is a no brainer that the particle count inside the home will get close to what is outside the home.
    Maybe regular AC circulates a house volume of air 4 times an hour, swamp cooler probably changes the inside air with outside air 10 times an hour.
    5,000 ft
    So.. What equipment are you using to test IAQ with?
