Results 1 to 13 of 19
    Customer wants 68 on 3rd floor???
    This customer would like to keep his upstairs third floor at 68 degrees but it just won't get there. The system is freezing up. I can keep the house at around 72 degrees. Is a standard HVAC system designed to keep an area this cool or is he looking for a refrigerator? This house is in Woodside California and the outside temperature is between 80 and 90 degrees.
    Florida
    Not many design temps in the 68 degree range. Get a dehumifier and they won't want it near 68 degrees, as it will feel cold in the low 70's,and the system will cycle properly then.
    Oct 2005
    Quote Originally Posted by JJMCAY View Post
    You may want to recommend that he/she upgrade to a walkin cooler. Just a thought.
    Apr 2006
    South West Ohio
    We have a doctor that keeps his second floor at 63 degrees. We use a freeze stat on the coil, low ambient kit on the outside unit. He has no problem keeping it there, it is oversized slightly.
    Apr 2004
    Charlotte, NC
    Quote Originally Posted by ryan_the_furnace_guy View Post
    Lovely thought. I wish I had one, love the 68 degree idea.
    manitowoc wisconsin
    I agree with the freeze stat & low amb kit.I would also use a delay on make with at least 5 mins to give the airsome time to defrost the coils.
    Take your time & do it right!
    Quote Originally Posted by markwolf View Post
    Good idea.
    I don't know
    Customer is therefore stupid and should learn to accept a more reasonable setpoint. Anything below 75F is wasteful.
    Jun 2007
    louisville ky
    Quote Originally Posted by amd View Post
    i now keep my house at 70. i just got a 3ton put in my house is 1200sq feet it is cold in here i like it
    Quote Originally Posted by chrism9232 View Post
    If they add the proper humidity controls to your new furnace, you'll be able to get your humidity down, and be just as comfortable at 72, to 74 degrees.
    Apr 2006
    South West Ohio
    Yes. The thermostat has a 5 minute delay built into it.
    Massachusetts
    The smallest zoned system that I know of for humans is an electric blanket on a double bed. Two controls, two temps. Now if you can't get two people who are sleeping together to agree on a temperature, what makes you think that someone should only be comfortable at the temps you're comfortable? My wife likes the bedroom cold enough that she has to use a comforter all summer. Fine with me, I like it cool too ('bout 67 @ 45% RH) but we're New Englander's and like the cold. Some other people don't even want AC. Go figure.
    Jul 2001
    Sell the customer a seperate system for the 3rd floor only.
