Results 1 to 7 of 7
07-18-2007, 08:57 AM #1
- Oct 2006
- 34
Is it normal to have a supply line run through a return (wall cavity)
I was taking off my return register and notice the supply line that runs upstairs from the basement runs through the return to get there. This is is how the system had been set up since the house was built (1975). Also is it ok to have a wall cavity (space between joist) serve as a return to your furnace.
07-18-2007, 09:00 AM #2
wall cavities (internal) are commonly used for return air.
"Surprised ?! If I woke up tomorrow with my head sewn to the carpet, I wouldn't be more surprised."
Clark Griswold
07-18-2007, 09:01 AM #3
having a supply run through the return is not common. Does it interfere with the return air ?
Clark Griswold
07-18-2007, 09:27 AM #4
- May 2006
- Dallas,tx
- 291
07-18-2007, 09:07 PM #5
- Dec 2006
- Long Island, NY/ Columbia, SC
- 223
by this do you mean you have an open return (as in no ductwork after the register) with the supply duct running through that space? if so, thats pretty common (commercial anyway)...
07-18-2007, 09:22 PM #6
If the system works it is ok, just leave it alone and put the register back, go watch TV before it breaks.
07-18-2007, 09:30 PM #7
Professional Member*
- Nov 2004
- SW FL
- 5,355
For A/C it should be OK and very rare.
For plumbing, I would say U have a problem.Designer Dan
It's Not Rocket Science, But It is SCIENCE with "Some Art".
