Results 1 to 13 of 24
    Jun 2007
    louisville ky
    i got my new furnace a heatpump in
    i got my new furnace and heatpump put in they started friday and finished it monday. i got a 70,000 btu goodman 95% 2 stage furnace model gmv95 and a 3 ton heatpump goodman seer 14 r410a model ssz14 with a whight rodgers touchscreen thermostat. so far i love it. thank you all for all your help!
    Jun 2007
    louisville ky
    anything i should know about what i got?
    Did they install a 2 stage stat?
    You got a good selection.
    Let's see
    Massachusetts
    Get it serviced regularly. Warranty doesn't cover routine service and that's the most important part of the purchase.
    Apr 2004
    Charlotte, NC
    Quote Originally Posted by chrism9232 View Post
    Al Gore would be proud of you. Nice choice.
    burlington county n.j.
    ...............nevermind
    Jun 2007
    louisville ky
    yes but the furnace said to set it to 1 stage, there is a switch down by the blower for the 2ed stage 5 min or auto it is at 5 min
    i also had a humidifier put in
    I don't know
    What you got is a convertible 2-stage furnace. When there's a call for heat, it should operate on 1st stage for up to 10 minutes based on the operating conditions (board has integrated logic) and than switch to 2nd stage. (When set to auto of course)
    Thermostat controlled staging is preferable, as it results in longer cycles on 1st stage as opposed to constantly switching between low, high and off.
    With the heatpump operating almost constantly in mild weather (32-40F), temperatures between rooms will still be quite even regardless.
    Hopefully the furnace an ECM blower.
    Jun 2007
    louisville ky
    Let's see
    i dont know how to post pictures on here so i posted them on a another forum im on here is a link
    http://www.f150online.com/galleries/....cfm?num=14360
    one of the pictures is on the new intake they added. they said i need more intake to add a 3ton heatpump. i still have the 4 small intakes i had before 6 inch pipe each. my house is 1200 sq feet but i do have 18 old windows. i had a 2 ton before and it was way to small
    Jun 2007
    louisville ky
    Quote Originally Posted by amd View Post
    is that bad?
    what is that and how do i tell?
    Jun 2007
    louisville ky
    I think the integrated logic only works in auto.
