    air conditioner compresser
    it seems to work when it wants to,at night late after midnight the compresser doesnt kick on,then in the morning it works fine,what could be goin on
    Illinois
    When was the last time...
    you had a qualified, reputable hvac contractor out to perform maintenance?
    Sounds like now would be a great time
    Fort Worth, TX
    Quote Originally Posted by salv97 View Post
    Have you tried lowering the thermostat setting that late at night? Late at night there's much less heat gain to the house from outside. If your thermostat is set high enough, the system may not come on at all.
    Also, if it is a programmable thermostat, check your schedule. If you need it cool at night you may need to set your nighttime temperature lower.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Apr 2004
    Charlotte, NC
    Yep, I agree. Yellow Pages from here.
    Florida
    A problem. Call for service.
    Southern NJ
    Talking
    Perhaps you have a programmable stat and IT IS working just fine.........
    I love to Cook...HVAC is a hobby that pays the bills!
