Results 1 to 11 of 11
    Nov 2013
    One system for 3800 square foot home/good whole house dehumidifier
    Hello,
    I'm building a home in Massachusetts.
    I was wondering if anyone could comment on my builder's plan to install just one system in our basement to heat/cool the entire house. It sounds weird to us but he's talking about stretch codes and all kinds of stuff I don't really understand.
    Can this be done? I also plan to install a whole house dehumidifier to help with my children's dust allergies. Any recommendations for best systems? Teddy Bear had recommended the Ultra Air on another thread and it seems to address both ERV needs (was also going to install one of those) and air filtration (up to MERV 14). The dehumidifier could help with the one-system plan.
    All comments most welcome...including best brands for the one-system approach if it's indeed realistic.
    Thank you!
    Oct 2010
    Doesn't sound realistic to me. is the basement included in the 3800sqft? If so how many sqft is the basement?
    Nov 2013
    Quote Originally Posted by jtrammel View Post
    No. This does not include the basement. However, we'll be finishing the basement at some point and at that point, it will include it.
    leland nc
    sounds like your heating and colling bills will be through the roof and you still will be struggling to keep up. I would think a complete load calc be done and two systems be install with merv 14 to 16 filter and also JMHO air knight or apco air scrubbers also
    Jun 2001
    Is the house 1 story above grade or 2?
    I don't doubt the whole house could be heated cooled with one system, it's even temperatures that I would be most concerned about.
    Oct 2010
    The ductwork would have to be perfect with a centrally located air handler, it "could be done" but most likely not by a general contractors hvac sub and his flex (residential new construction) brigade. I would go with 2 or 3 smaller units. One for master suite etc one for up and one for down possibly. I'd have to look at the prints and do some calculations to know exactly how I'd do it.
    SW FL
    MERV 7 Filter is MORE THAN ENOUGH for the Equipment.
    Filtration is FOR THE EQUIPMENT, NOT THE OCCUPANTS.
    Build yourself an R-40 FOAMED "Igloo" and your heating requirements will be
    < 48,000 BTU/HR
    Designer Dan
    Nov 2013
    Quote Originally Posted by 54regcab View Post
    I'm sorry..."even temperatures?" So the one system could work with some limitations?
    Nov 2013
    Really? I thought I was saving money by having the filtration built in.
    My builder said that one system means it will run nearly constantly which will help with the humidity issues (lots of wetlands around her). He also built his own home with one system. One additional item...we're spray-foaming our attic--in case that makes a difference.
    - - - Updated - - -
    Two stories above grade.
    Jul 2001
    Gold Coast of Connecticut
    The advantage is one system to maintain and repair, if it breaks you have no cooling.
    With one system you should go to multi stage equipment and set it up so if one zone calls for cooling it can run in low stage. Or better yet use one of the OEMs contrl systems to control the zoning and staging.
    Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
    Jun 2001
    Quote Originally Posted by newhomebuild View Post
    It probably would keep the house warm/cool. Some rooms may be cooler/warmer than others. It takes a well designed duct system for even temperatures in all rooms to happen. As jtrammel stated it's unlikely for most residential installs.
