Results 1 to 13 of 14
    Nov 2005
    You Have to Change T-Stat for 14 seer.
    Hey guys,
    I have a customer witha 3 year old honeywell stat, and he wants to add A/C.
    He was told by another company that he has to change out his stat to get 14 seer because of cycles per hour. I have never heard of this before, is it crap? I know newer stats can be programmed for cycles per hour, but how would the stat know the seer rating of the equipment?
    I STARTED WITH NOTHING, AND I STILL HAVE MOST OF IT!
    Southern NJ
    The Stat won't know and won't care what the seer rating is. A change of the stat may be necessary if you have a 2 stage cooling and a 2 stage heating system.
    What cycles per hour are you referring to? Cooling cycles?
    I love to Cook...HVAC is a hobby that pays the bills!
    Toledo, Ohio
    Quote Originally Posted by emoney1971 View Post
    Hey guys,
    Tell your customer that your the only one he can get mis-information from.
    No Heat No Cool You need Action Fast
    Nov 2005
    From your lips to God's ear.
    Rochester, MN
    I think they are trying to make money.. As said, the t-stat won't know if it's a 5 SEERS or 22 SEERS.. As long it works in cooling it's fine.. True, newer ones has CPH settings.. You know what the model of the current t-stat is?
    Sep 2003
    Becareful guys. He may need a time delay of some sort to get 14 SEER and the contractor prefers to use a thermostat time delay rather than a time delay relay AT the furnace.
    Toledo, Ohio
    Quote Originally Posted by heatingairman View Post
    How will time delay increase seer?
    Sep 2003
    Quote Originally Posted by twilli3967 View Post
    If you look on ARI's website, some match ups need a TDR (time delay relay) in order to reach a certain SEER.
    Toledo, Ohio
    You could be correct, I have never read or heard that, but hey even Twilli can learn something. The equipment that I install the ecm motor ramps up slower and helps with humidity removal by making the coil colder. Also isn't this adjustment usually made at the furnace????
    Sep 2003
    YES!!! It is USUALLY made at the furnace, however some furnaces do not have a TDR built into the circuitry (especially old units). Also, some states will not recognize an ECM motor for an increase in SEER, like WISCONSIN!!!!!
    It's very frustrating! Hopefully someone from Focus on Energy will read this post!!!!!
    Toledo, Ohio
    I guess I was assuming
    Philadelphia, PA
    ... that everyone installs Coleman?
    Virginia
    i installed a 5 ton trane last week that that took a 401 tstat to be 14 seer but not really sure y
