Results 1 to 9 of 9
Thread: Summit Coils
    Feb 2005
    Toms River, NJ
    Summit Coils
    Hello everyone. Need some help with a model number on a Summit Coil. The model # is CA2N58-MF the coil is approx. 10 yrs. old. Does anyone know what size coil this is? Also, is there a TXV in this or a piston. Thanks in advance guys....
    Dave in NJ
    Jun 2001
    Louisville, KY
    Are you sure about that number? I can't decode it.
    http://www.summitmfg.us/images/pdf/S...menclature.pdf
    Might want to give them a call. They are in Texas -- Central Time Zone.
    1-800-944-6354
    Sep 2006
    Winter Springs, Fl
    I saw one of these branded coils once on a unit that had hot water reheat instaed of electric heat strips. The brand of the AHU was suntherm but it was kinda of a dated design. The one I saw had a piston/ fixed metering setup.I'm not to sure on decoding that coil # but I would think it's in the 5 ton range.
    I hope this helps.
    If you can't learn to do something well, learn to enjoy doing it poorly.
    VETO PRO PAC - The Official Tool Bag of HVAC-Talk.com
    Massachusetts
    Sounds like an old coil. The current Summit line is labelled CA024A862, which is approximately 2-tons, depending on the condenser it's attached to. So as a reasonable guess, I'd think it's a 2-ton, old unit.
    Feb 2005
    Toms River, NJ
    I dont want to make the mistake of guessing its a 5 ton coil just because it has a 58 in the model number. Its matched up to an Air Pro condenser, and the model number is too faded to read. I took the numbers off the compressor and plugged them into this cool website (www.bristolcompressors.com/ProdCrossRef.aspx) if anyone is interested. and it comes back with a ARI rating of 37,899 btu. Thats why I am alittle hesitant about assuming its a 5 ton coil. I think I will take jrbenny's advice and call Summit in the morning. Thanks again,
    Dave in NJ
    Sep 2006
    Winter Springs, Fl
    Quote Originally Posted by smadave View Post
    Dave in NJ
    yeah it was a shot in the dark but it was just a guess. I would be more inclined to think the same as you. I didn't know that summit was still around. call them but I would doublecheck the numbers you got off of the coil to make sure you read them right. good luck
    Feb 2005
    Toms River, NJ
    I called summit today...they dont know either! Go Figure...
    Dave in NJ
    Jun 2001
    Louisville, KY
    Dave in NJ
    Reason number 5,092 that we quit selling their products.
    Sep 2006
    Winter Springs, Fl
    Dave in NJ
    Sounds like a good time to sell the customer some new equip.
