    Nov 2013
    Carrier Infinity Comparison
    Please advise on differences,advantages,or disadvantages. From specs one evaporator coil is 3 ton and the other 4 ton but not sure relevance. Thermostats are different but curious if this Infinity Thermostat is still available and recommended? systxccuid01 . Finally one contractor stated humidifier not option size/mount issue that's why no comparison. Is this Infinity HUMCCSBP same as Aprilair 600.
    Furnace 58CVA090-16
    Air Conditioner 24ANB736
    Evaporator Coil CNPVP3617
    Media Filter?
    Thermostat TPPRH
    Humidifier Aprilair 600
    Furnace 58CVA090-16
    Air Conditioner 24ANB736A30
    Evaporator Coil CNPV4821A
    Carrier Filter Cabinet EZXCABCC1016
    Thermostat SYSTXCCITN01
    Humidifier NA
    Quote Originally Posted by Maybe View Post
    Furnace 58CVA090-16
    Media Filter?
    Thermostat TPPRH
    Furnace 58CVA090-16
    Humidifier NA
    The Tstat systxccuid01 is the old style and probably the ugliest Tstat ever invented.
    SYSTXCCITN01 is communicating and the EDGE Tstat is not but both are comparable and nice looking.
    The humidifier is the same.
    The difference between the coils should be based on the latent and sensible load of your home as determined by the Manual J load calculation.
    Nov 2013
    Thanks, both coils were recommended but different contractors which one should I go with?
    Which ever one matches the Manual J load calculation for your home.
    Apr 2011
    SE Washington
    the cnpvp3617 physically matches this furnace and is the correct ari match for the a/c, its 17 inches wide versus the 21 inch 4 ton coil which would require a transition to accomadate
    Aug 2013
    Visalia California 93291
    In our area you cannot even get the old style of UI anymore just the Touch and Go and Touch and Go WiFi, we only install the WiFi
    I see a lot of contractors quoting the ANB7 on lower tonnage units when the ANB1 makes more sense until you get to 4 tons and higher
    Make sure a Man J and Man S gets done
